Old 04-19-2014, 01:08 PM   #81
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Originally Posted by Bimme323 View Post
Ok. Replaced the spark plugs to one step colder. Replaced jets to 0.25 nitrous .014 fuel.
Did 4 runs car ran smooth with an A/F ratio of 12:3 in all 4 runs.
Now i feel the pull on 2nd and 3rd gear.
Pretty much im making near 25 whp.
Next run will be nitrous .028 nitrous .015 fuel.
That will put me in the 30s
On your next run, use a .016 fuel jet instead of a .015; I'd like to see it slightly richer than 12.3 AFR.
SUMMIT POINT WV 1:24:229 SCCA
Old 04-19-2014, 05:04 PM   #82
330Cole
My Ride: 01' 330Ci
I'm following this thread very closely now... About to do the same in my car. I sorted out all the other issues and come summer ill have $ to buy a kit. Rob had advised me earlier and it looks as tho OP is doing something similar. Good luck! Can't wait to see the 75
  • KW V1
  • Meyle HD Diff & Subframe Bushings
  • Meyle RTAB & TMS RTAB Limiter kit
  • Lemforder ZHP HD Control Arms
  • Meyle HD FCAB
  • TMS Subframe Reinforcement kit
  • TMS Swaybars F/R & Adjustable Endlinks
  • 3.38 Open Diff
  • BMW Performance SSK
  • BB Gen 3 Headers
  • Eisenmann Race Exhaust
  • 3.5" Longtube CAI
  • 3.5" Conforti Eurosport Filter
  • Shark Injector
  • Stoptech Slotted Rotors
  • TMS SS Brakelines
  • ST Sport Pads
330Cole is offline   Reply With Quote
Old 04-24-2014, 09:11 PM   #83
Rob43
Rob43's Avatar
^ Thanks Cole.
OP, have you refilled your 5 lbs bottle yet ?
Old 04-25-2014, 06:38 AM   #84
Bimme323
My Ride: Bmw e46
Not yet. Will do tomorrow.
Bimme323 is offline   Reply With Quote
Old 04-26-2014, 04:48 PM   #85
Bimme323
My Ride: Bmw e46
Ok bottle filled up. I did skip the 35 shot and went 40 shot. Used .030 nitrous .017 fuel.
3 runs A/F r was 12:4.
Now i feel a good pull. Road was a little wet lots of wheel spinning. I have schedule a dyno run for next saturday. We will do 3 runs
First run no nitrous
Second run .030 nitrous .017 fuel
Last run .032 nitrous .019 fuel
That will be my goel 50 shot.
Will post the results next saturday.
Old 04-26-2014, 05:27 PM   #86
Rob43
Rob43's Avatar
That's good, a few thoughts.
Try to get your AFR in the 11's, anything between 11.5 & 11.9 would be good. It's simply safer for your motor this way. When you go in for your Dyno next week make sure you bring Extra fuel jets in case you need to richen it up. Between runs, try to let your bottle heater "Recover", meaning let it get your bottles PSI back to whatever your starting point (950) is. This of course will give you more accurate & consistent tuning information. Also, no matter how much nitrous you think you have left in your bottle, get it refilled Before your Dyno session, it would be a waste of money if you were to run out of nitrous right in the middle of Dyno testing.
Enjoy,
Rob43
Old 04-26-2014, 06:11 PM   #87
Bimme323
My Ride: Bmw e46
Just went for 3 more runs. A/F rate drop to 11:9 than goes up to 12:3
Actually for my luck at the dyno place they sell nitrous. I get the pressure recovery.
Again i will call this project accomplished. Now comes the fun part.
Old 04-26-2014, 06:41 PM   #88
Tylerhagens
My Ride: E46 m3
Originally Posted by JasonLI25t View Post
good tymes, good tymes.
I ran a 75shot wet kit close to same setup on a Acura RSX type s for years. Dont hate on this guys set up. I am about to go direct port on my m3.
Tylerhagens is offline   Reply With Quote
Old 04-27-2014, 10:26 AM   #89
Bimme323
My Ride: Bmw e46
Just went with the 50 shot
5 runs .032 nitrous .019 fuel
A/F was between 11:4 to 12:1
Rob should i go up to .020 on fue to be a bit richer on fuel?
Old 04-27-2014, 12:32 PM   #90
PEI330Ci
58mm of Bliss
PEI330Ci's Avatar
My Ride: 330i, 330Ci
What was your starting bottle pressure for each pull?
Old 04-27-2014, 12:52 PM   #91
Bimme323
My Ride: Bmw e46
Between 900 to 920psi
Old 04-27-2014, 01:36 PM   #92
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
BMW 323i nitrous FINALLY!!!
What nice about ur hp numbers is that it's square across the whole rpm range. Meaning the torque is equal and instant. That's what makes u feel the difference. Lots of mods increase hp at peak but not many do torque and that's where the fun is
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 04-27-2014, 01:48 PM   #93
Bimme323
My Ride: Bmw e46
I will know next saturday at dyno.
Old 04-27-2014, 03:50 PM   #94
Rob43
Rob43's Avatar
Everything seems pretty perfect there, those numbers are what I'd consider to be good based on the factors you've given us. The thing to do now would be Check Your PLUGS. Bring the appropriate tools and a camera (take several GOOD pics) with you on your next run, make a full nitrous pull & shut the motor off Without dropping your RPM back down. Bring a big piece of paper that you will mark with a Sharpe, number the paper 1-6 so you can lay each plug on the corresponding number to know what cylinder it came from. This is very important. Now you'll have several great pics per spark plug & you'll know what cylinder each one came from. Reading your plugs will let you know if you really need to "Tweak" something, like adding a larger or smaller fuel jet.
It's looking good,
Rob43
Old 04-29-2014, 06:52 AM   #95
aahmed2016
My Ride: 2003 330i ZSP/CP/PP
Originally Posted by Alan L. View Post
Either way flammable or not this could happen
http://www.dragzine.com/news/overhea...-of-a-mustang/
Originally Posted by MercForHire View Post
Spends $2000 on car DVD + stereo -> Running 25000 mile oil changes and 87 gas with blown shocks
aahmed2016 is offline   Reply With Quote
Old 04-29-2014, 09:32 AM   #96
Bimme323
My Ride: Bmw e46
Thanks for the tip guys. Ill make sure not to drive on their streets!!
Old 04-29-2014, 05:48 PM   #97
Rob43
Rob43's Avatar
Consider working out a deal with the dyno shop beforehand for the possibility of more than the standard 3 pulls. You might need/want 4, 5, or 6 total pulls, see if they'll charge you some small amount per pull after the first 3 dyno's. This way you'll be able to maximize your dyno time & tune it to whatever HP rating you want, while knowing you have a set price for the extra pulls you do.
Bring all your jets with you, hopefully the dyno shop also has any needed jets for sale if you need them.
Rob43
Old 05-03-2014, 07:26 AM   #98
Bimme323
My Ride: Bmw e46
At the dyno. Will post results shortly.
Old 05-03-2014, 08:14 AM   #99
milKt
My Ride: air/fire
Noice.
milKt is offline   Reply With Quote
Old 05-03-2014, 10:28 AM   #100
Bimme323
My Ride: Bmw e46
Here a pic
