Old 04-05-2014, 10:54 PM   #1
Tippey764
My Ride: 2002 Touring
Send a message via AIM to Tippey764
Running too lean, now too rich
Alright i'm getting confused with this car already.
I was getting a p0171 and p0174 for a few weeks. I was slowly replacing everything trying to find the leak
Intake boots
Disa valve
CCV with all related hoses
vacuum lines
Finally today i replaced the CCV
Now i went from getting lean codes to getting P0188 and P0189 for running rich
What happened? Can i ever win with this thing?
Its a 2002 325xi with a m54b30 swap. A lot of maintenance has been done with the swap but i just can't figure this problem out.
Tippey764 is offline   Reply With Quote
Old 04-06-2014, 08:29 AM   #2
lszlszx
My Ride: 1.8T, XC70
Does your scan tool read freeze frame/live data?
Post freeze frame info.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-06-2014, 10:46 AM   #3
Tippey764
I'm using PAsoft1.4
Old 04-06-2014, 10:59 AM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
Intake boots
Disa valve
vacuum lines
Are we talking about P0188 and P0189 or P1088 and P1089?
Bentley does a VERY poor job with both of these codes.
What tool did you use to pull these codes and what was the EXACT code? Did you translate the code from a Hex or Decimal code?
Either way, doubt you have a rich problem.
Likely a lazy O2 sensor and/or a lean condition.
As mentioned, need fuel trims.
Also best to flag bad O2 sensor is with a smart phone App and an OBDII interface.
http://forum.e46fanatics.com/showthread.php?t=967204
Old 04-06-2014, 11:01 AM   #5
jfoj
I'm using PAsoft1.4
Ditch PASoft for OBDII, useless as it usually gives no Live/Real Time or Freeze Frame data for most DME's.
Is the SES/CEL/MIL light on?
Get yourself a decent quality generic OBDII tool or a smart phone App and interface as I mentioned.
Old 04-08-2014, 10:49 AM   #6
Tippey764
Alright so I got a real scanner that can do freeze frames and here's what I got
Pasoft was giving me a hex code that I thought was a rich code but this scanner is giving me the lean code. Whatever I'm stumped.
Code: p0171
Engine rom: 2976
Calculated engine load: 23.1%
St fuel trim 1: 15.6
Lt fuel trim 1: 11.7
St fuel trim 2: 14.8
Lt fuel trim 2: 11.7
Vehicle speed 84 km/h
Fuel system 1 closed
Fuel system 2 closed
My long term fuel trims are always at 11.x even when the car is off
Yep you were right I must have translated the code incorrectly. The real codes are p0171 and p0174
Yes the check engine light is on
It's also consuming a bit of oil and the throttle has a horrible lag in it. It holds the throttle for about 1-2 seconds after you lift off. No this isn't the normal complaint, you literally feel the car still accelerating after you lift off.
Old 04-08-2014, 10:53 AM   #7
msane3
My Ride: 2007 335i
It could be a valve cover gasket leak, intake manifold gasket, or even bad o2 sensors. More than likely valve cover gasket due to the oil consumption
msane3 is offline   Reply With Quote
Old 04-08-2014, 11:18 AM   #8
jfoj
Code: p0171
Engine rom: 2976
Ok, now we have real data.
So 52 MPH and almost 3k RPM and you are running lean.
This is NOT a basic crankcase or intake air leak.
This is NOT likely due to bad O2 sensors.
This problem is somewhat loaded due to the fact this was an engine swap and there is not enough detailed info on what went down, what parts were swapped, what DME is in the car and when these problems surfaced.
If this was an unmolested car, I would likely say cheap/counterfeit/clone MAF, but we have all sorts of options to include O2 sensor wiring swapped, wrong O2 sensors, wrong DME, wrong MAF, and possibly hacked wiring. Could even be a basic fuel delivery problem as well.
So not sure this problem can be sniped, but a shotgun may be a more suitable tool at this point.
Old 04-08-2014, 11:51 AM   #9
Tippey764
I did the engine swap so I can shed some light on what parts were used
-The wiring harness is the original 325 engine harness no wiring was hacked either
-The DME is the 325 DME. I took the car after I had the swap done to have it flashed with 330i software
-The o2 sensors were reused from the 325 engine. According to realoem they are the same part as the 330. The old engine had low compression and was sending unburnt fuel out of cylinder 6 into the exhaust. The old engine was not giving me codes for the o2 sensors though
-The MAF was purchased used from a guy who pulled it from a tracked e46 he told me he was having problems with his car and swapped in a new MAF to see if it was causing his problem. He said the new MAF didn't help and it was something else so the MAF was good
- I am running the full 330i intake
How could I test a MAF? Would the data revolving around how much air it's recording be important?
Old 04-08-2014, 11:54 AM   #10
Tippey764
I can't imagine a quart of oil every 1000-1500 miles is leaking out of the valve cover gasket
Also to go over maintenance items replaced with the swap
Oil pan gasket
Oil filter housing gasket
Vanos line to oil filter housing
Thermostat
Water pump
Coolant over flow tank and bracket
Vacuum line to egr replaced
Rubber intake boots replaced
All exhaust gaskets including manifold gasket replaced
Ccv system and all associated hoses
The only thing I haven't replaced is the spark plugs actually. I have a photo of their condition I could post if that's relevant to anything
Old 04-08-2014, 12:23 PM   #11
jfoj
You could test the engine load using the scan tool. If the engine load ever goes above 100% when goosing it in 3rd gear, this is a key indicator that something is wrong.
Also it is likely the MAF is a cheap Asian knock off/counterfeit as a real 330 MAF is over $275. Someone is not likely going to give you a real 330 MAF.
The other thing I would suggest, unplug an O2 sensor and see if it corresponds to the proper bank. See this all the time, people swap the wiring for the O2 sensor it drives the DME nuts.
Old 04-08-2014, 12:29 PM   #12
Tippey764
I'll check the MAF but I'm pretty positive it's a genuine bmw part
I'll double check the o2 sensor wires as well. I did number them as I took them apart but I could have made a mistake. The marker didn't write every well and I might have mixed it up. Would after cat o2 sensors matter or only the pre cat ones?
Old 04-08-2014, 12:53 PM   #13
jfoj
Both sets of sensors pre and post cat should be verified.
Pretty easy to do if you have an OBDII tool that will display Live/Real Time data.
Old 04-08-2014, 12:54 PM   #14
Tippey764
For the record bank 1 is the front of the engine right? Silly question but I want to be sure.
Old 04-08-2014, 01:03 PM   #15
jfoj
Inline 6 engines: Bank #1 = Cyl 1-3, Bank #2 = Cyl 4-6
Old 04-08-2014, 07:37 PM   #16
lszlszx
My Ride: 1.8T, XC70
[QUOTE=Tippey764;16094312]I can't imagine a quart of oil every 1000-1500 miles is leaking out of the valve cover gasket
That's correct, it takes a huge leak to lose that much oil.
As far as the codes are concerned, I would look at how STFT are at idle and under load at higher rpm, that could be another clue.
Old 04-09-2014, 07:26 PM   #17
Tippey764
Couple things tested today
I did a smoke test using both the ccv where it enters the valve cover and at the intake air temperature sensor location and didn't have any leaks at all. Everything seems tight
I did a fuel pressure test and got 45psi when I cycled the key on and a running PSI of 55. I did do a fuel pressure bleed down test and I did lose my pressure over 45 minutes. I'm not sure if that's normal or not though.
Old 04-09-2014, 07:54 PM   #18
Tippey764
Oh yeah my MAF is a genuine Siemens MAF. So I just tried unplugging it and driving it around and my hanging throttle seems to go mostly away. It doesn't go entirely away though.
Old 04-09-2014, 10:02 PM   #19
Tippey764
Alright some more info
I swapped the MAF with a known good MAF. I'm still getting 11.7 long term fuel trims for both banks
Under idle the short term fuels trims drop to between -10 and -15
Old 04-10-2014, 05:29 AM   #20
Tippey764
I cleared the codes when I swapped the new maf in. I watched it start at 0 and climb to 11.7 as I drove home
