Go Back   E46Fanatics > Other BMW Models > General BMW Model Discussion
All non E46 BMW model questions in here. Look below for E36, E90 and F30 specific forum. For additional model specific forums check out bimmerfest.com!
Old 04-07-2014, 09:57 PM   #1
Mau330i
My Ride: '02 330i
Help with N62 Engine Please
This engine belongs to a 2002 745i. It was hydrolocked about 8 months ago (thats what I was told) and the owner wants me to fix it. Right now the engine does not turn (not even with a wrench)
I think the pistons rod are bent or something like that.
Have somebody here had work with one of this engines??
Is it fixable??
Do you think it is worth the job??
Any help will be really appreciated.
Thanks in advance
Mau330i is offline   Reply With Quote
Old 04-08-2014, 03:35 AM   #2
blarf
My Ride: 323i, 325iT, 540iT
All I learned about the N52 I learned from this: http://forums.bimmerforums.com/forum...-out-of-my-550
Whether it's worth it is up to the owner, but rebuilding an N52 ain't gonna be cheap. IMO BMW designed the engine to be disposable, and you're probably headed for fewer frustrations if you were to just buy a long block from them. The things that stick out in my mind:
- Alusil lining means that you can't rebore the cylinders
- Rings are a few grand for a set
- Lots of stuff will be worn (valve seals, valvetronic, potentially VANOS stuff, etc) and need replacement
But more importantly, if you can't turn the engine over... are the pistons rusted in place? If so, you're probably better off looking for a new block anyhow.
Originally Posted by howie View Post
do you park near poodles?
blarf is offline   Reply With Quote
Old 04-08-2014, 10:11 AM   #3
lszlszx
My Ride: 1.8T, XC70
Too much trouble. The engine needs to be completely disassembled even just to see the damage. Both heads, oil pan, pistons and rods need to be taken out.
Considering the cost of a rebuild and the time it takes to do it, it make more sense to source a used engine.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-08-2014, 10:32 AM   #4
unevolved
My Ride: 2003 325i
There's no way that'll be cost-effective to fix. I vote replace the long block, at least.
In a bacon and egg sandwich, the chicken is involved, but the pig is committed. Be that pig.
unevolved is offline   Reply With Quote
Old 04-11-2014, 01:56 PM   #5
Mau330i
My Ride: '02 330i
Thank you all very much!!!
The owner insists on repair the engine
I think I will not take the car....
Thanks a lot!!!!
Old 04-11-2014, 03:15 PM   #6
unevolved
My Ride: 2003 325i
You could tell him you're repairing it, and just replace the short block. Most of the original stuff will still be there (heads, etc.) so it's mostly true!
