Old 04-08-2014, 08:08 PM   #1
BMW323ciDriver
My Ride: 2000 bmw 323ci
2000 Bmw 323ci - Transmission Gear Noise (VIDEO)
The car makes a loud shape noise when shifting gears from park to reverse. Sometimes when driving it makes the same noise when changing gears. What could this problem noise be? And how to fix? Video Below.....
You can really hear it at :32 seconds into Video.
BMW323ciDriver is offline   Reply With Quote
Old 04-09-2014, 04:05 AM   #2
BMW323ciDriver
I really need some bmw/e46 experts here...I need this fixed! What can it be? Simple as low ATF? Or bad as tranny replacment? Much appreciation for anyone that helps...Thank you
Old 04-09-2014, 04:09 AM   #3
Stickbuilder
My Ride: Touring, and others
What is a, "Shape noise"?
[/SIGPIC]I'm fluent in 3 languages:
English
Sarcasm
Profanity
Stickbuilder is offline   Reply With Quote
Old 04-09-2014, 02:23 PM   #4
BMW323ciDriver
I just put sharp noise since I didn't know how to describe it. Did you see the vid? Every time I put it in gear it kinda kicks hard with like a screech grind click. Almost like the gears could be rubbing together.
Old 04-09-2014, 08:33 PM   #5
ChuckyVee
My Ride: 2000 323i, '99 328is
Well...that's your differential so I'd try draining and refilling the gear oil first....not the ATF.
Cheap, easy, and quick and if it turns out that it doesn't fix it you're not out a lot of time and money.
I have to say that sounds HORRIBLE! definitely metal to metal contact. Changing the gear lube can't hurt!
First Bimmer..."Miss December"...2000 323i, purchased Dec. 2013 w/82K on the clock. PM thus far...pads/rotors, belts/pulleys, complete CS overhaul, FCABs, plugs, autotranny/differential service, fuel pump, filter, and relay. Full front end refresh with LCAs and bushings, struts and mounts, inner/outer tie rods, sway bar endlinks and bushings.
ChuckyVee is offline   Reply With Quote
Old 04-09-2014, 10:15 PM   #6
lszlszx
My Ride: 1.8T, XC70
Check the gear lash in the differential.
Have a helper shift back and forth, reproducing the sound as you listen.
Also keep an eye out for worn differential bushings, bad CV joints and U joints.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-10-2014, 03:47 AM   #7
BMW323ciDriver
Thanks for the reply guys, I will try changing the Differential oil and while I'm at it just inspect the whole under side of that area looking for anything worn. I'll keep updates! Possibly make a better video as well.
Old 04-10-2014, 10:35 AM   #8
Cavi Mike
Banned User
My Ride: 2000 328Ci
Send a message via AIM to Cavi Mike Send a message via MSN to Cavi Mike Send a message via Yahoo to Cavi Mike
Didn't anyone notice how much the differential was moving? Seeing as you couldn't stop moving the "camera" for more than 1 second at a time, it was hard to tell what else was moving but I did see your sway bar was moving as well - that means the subframe is moving and it could either mean your subframe bushings are shot OR you have the dreaded subframe mount problem.
Cavi Mike is offline   Reply With Quote
Old 04-10-2014, 03:54 PM   #9
dalefj
My Ride: 2003 330Ci
I agree, from how much it looked like the differential was moving I would guess the noise is coming from one of the drivetrain supports. Best of luck and keep us updated.
dalefj is offline   Reply With Quote
Old 04-10-2014, 06:14 PM   #10
BMW323ciDriver
Update and confirmed!
Well guys, looks like Cavi Mike was right on the money with this one. Subframe Damage Found!
First video below shows a much better view of the differential and the noise...and the last video shows the damage in action direct.
So now the question is How the hell do I repair this? Is it even possible?? Will driving on the damage cause further damage? I read Bmw had a lawsuit years back, but now not anymore? Am I SOL here? Please Advise. Thank You
Old 04-10-2014, 06:43 PM   #11
ChuckyVee
Well that sucks!
I'll let those that are more knowledgeable than me chime in on what your best options are at this point.
I feel for ya man!
Old 04-10-2014, 07:23 PM   #12
ReIntegration
My Ride: 2003 BMW 330Ci
Send a message via AIM to ReIntegration
Wow, just like my buddies 328Ci.
http://www.activeautowerke.com/pdf/product99a.pdf
Either way the whole back has to come out! Everything! You need to do some welding or a Pro. My friend had a shop do it. Was expensive. I tried to talk him out of it cause it was more than what the car was worth but he wasn't trying to hear that. He loved the Sh*t out of it and paid out the ass, but it was repaired and he had the car for 4 more years with no problems.
']['|R(G
Wernher Von Braun
2001 330Ci (My uncle was the original owner then given to me as a secondary to my 03)(Sold)(Kept younger brother)
2003 330Ci (Current & original owner - Born on 1.10.03)(Had it since new born. Delivered from Regensburg on 2.24.03)
Originally Posted by Mordecai
Ready to get destroyed?
ReIntegration is offline   Reply With Quote
Old 04-10-2014, 11:56 PM   #13
BMW323ciDriver
Oh man, I'm a hardcore DIY'er, but i know nothing about welding and this looks incredibly time consuming and difficult to work on. Especially if I screw up some where. And I don't want to spend more money then the car is worth...damn, looks like I don't have really any options here.
Old 04-11-2014, 12:02 AM   #14
SoCalZman
My Ride: 05 BMW 330i ZHP 6MT
Wow. Bummer. Another one bites the dust. I have seen threads with much worse damage get repaired so it is possible. It'll just cost you a few thousand. Where in Cali are you located?
2005 BMW 330i ZHP 6 speed
Stock: Nav, leather, PDC
Added by me: OEM Alarm, OEM heated seats, OEM aux kit, OEM Bluetooth, intravee, M3 strut brace, BMW Performance Intake, Nappa leather arm rest, updated LCM (triple blink, euro hazards, trifecta lighting, 3 stage brakes), temp gauge mod
SoCalZman is offline   Reply With Quote
Old 04-11-2014, 02:25 PM   #15
BMW323ciDriver
I live in the bay area. Union City to be exact.
Old 04-11-2014, 06:29 PM   #16
SoCalZman
Give Performance Technic a call in Pleasanton. They've done two of these repairs/retrofits to friends of mine (M3's). Maybe they can save your car.
