Old 04-09-2014, 10:44 PM   #1
XxJeffxX
My Ride: 2002 330ci
Squeal on cold start, and 1500 RPM, New Pulleys and Belt!
Alright guys now I know what you'll say, use the search function and i've been doing this the past few days with no answers to my problem. So i recently did the whole cooling system and changed out my belts and pulleys since i was there, after a few days of no noises a loud annoying squealing sound started on cold start up and lasted until engine was fully warm, however it would still slightly squeal under acceleration. I've taken all the belts off and inspected all the pulleys i installed about 4 times, and even tried a little silicon spray in the pulleys(i know its a closed system but i'm desperate). I even took off both belts and washed them down with soap and water thinking it was slipping but the noise is still there So as of now i'm stumped guys, i changed all the pulleys, which include the idler pulley, alternator deflection pulley, and AC tensioner pulley, and replaced the belts, but still have that squeal. Any insight on what might be happening? i'm starting to think that the meyle deflection pulley i got was defective because it appears to be coming from that area.
XxJeffxX is offline   Reply With Quote
Old 04-09-2014, 11:51 PM   #2
XxJeffxX
My Ride: 2002 330ci
Originally Posted by lszlszx View Post
Could be something else like water pump, alternator, or power steering.
Just changed the water pump for alternator it doesn't sound like it could be it, when i rotated it with the belts off it had no noise to it.
Old 04-10-2014, 12:32 AM   #3
lszlszx
My Ride: 1.8T, XC70
Give it some time.
It may get better, or worse, in which case it'll be easier to tell where the squeal is coming from.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-10-2014, 12:41 AM   #4
Cbibbss
My Ride: 2003 325i
I had same problem. Make sure you replace with OEM parts. It squealed and didn't stop until I replaced pulleys and tensioner because they were poorly made (duralast from autozone). Don't BS on parts! Trust me!
Cbibbss is offline   Reply With Quote
Old 04-10-2014, 11:24 AM   #5
LeoArellano
My Ride: 2001 330xi
The new belt might be a tiny bit longer. I had the same problem, replaced my belts and pulleys, I was hearing a squeal while driving turned out the new belt was longer by like a couple cm. I put the old one back one and the noise went away.
LeoArellano is offline   Reply With Quote
Old 04-10-2014, 05:28 PM   #6
marblesmike
My Ride: 2002 325ci
I have the exact same issue after doing all the same work. I got a stethoscope and had my buddy listen while I pressed on the gas....sound pinpointed to the alternator. Maybe spilling coolant and some getting into the alt is the cause. Anyways, I'm going to wait until it gets louder and more annoying before changing the alt. Remanufactured ones can be found on Amazon for ~$160 or around the same price from Advance Auto with online coupons.
As for the OP not thinking it's his alternator, there are internal components that can make that squeal noise. How do I know? I sprayed a bit of WD40 into the alt and the sound temporarily went away.
marblesmike is offline   Reply With Quote
Old 04-10-2014, 11:32 PM   #7
XxJeffxX
My Ride: 2002 330ci
I used meyle pulleys and continental belts, i'm considering getting oem though since the sound hasn't really changed
Old 04-10-2014, 11:33 PM   #8
XxJeffxX
My Ride: 2002 330ci
I asked what the length was for OEM from the dealer and the one i got is the correct one, thanks though!
Old 04-10-2014, 11:34 PM   #9
XxJeffxX
My Ride: 2002 330ci
Do you suggest i do these to the individual pulleys to see where the noise is coming from?
Old 04-11-2014, 05:37 AM   #10
David McMahon
My Ride: '99 E38 740iL
Not sure if it even applies, but I've just had to change the crank pulley on my Peugeot 206 to stop it eating belts, much quieter now.
David McMahon is offline   Reply With Quote
Old 04-11-2014, 09:06 AM   #11
marblesmike
My Ride: 2002 325ci
I suggest you get a cheap mechanics stethoscope and listen to each component that could be making the noise.
Old 04-11-2014, 10:37 AM   #12
XxJeffxX
My Ride: 2002 330ci
Ok i'll definitely try that, thanks,
Old 04-11-2014, 11:55 AM   #13
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
When you say you replaced your pulleys, which ones did you replace? I assume the idler pulley and two tensioner pulleys.
Keep in mind there are some pulleys that can be replaced independently of the bearings they ride on, such as the water pump pulley and power steering pump pulley. IIRC, the alternator pulley can also be replaced independently of the alternator bearings. If you've replaced any of these pulleys and the noise still exists, then the bearings are probably going bad.
Old 04-11-2014, 08:03 PM   #14
XxJeffxX
My Ride: 2002 330ci
alright guy i'm pretty sure i pinpointed the problem, its the alternator deflection pulley, i used a stethoscope to track down the noise and sprayed some silicon lubricant on the pulley to see if the noise would go away, low and behold it was that new pulley i had just replaced, so i'm guess it was a defective part, so i'm going to go ahead and order an OEM pulley next week, i'll keep you guys updated but i'd like to thank all of you that answered, and helped me out with this problem, you guys are great! and the only reason i love the bmw community and no one else!
