Old 04-12-2014, 11:29 AM   #1
yannis4ny
My Ride: 2004 325ci vert
Weird rubber found during DIY
Hey guys, I was replacing the clutch fan today and dropped the antifreeze screw down the bay. I had to remove it to get it and found another rubber piece that I have no idea where it is coming from... I have attached a few detailed pictures of "it". Any help will be greatly appreciated...
ID:	553670   Click image for larger version
ID:	553671   Click image for larger version
ID:	553672   Click image for larger version
yannis4ny is offline   Reply With Quote
Old 04-12-2014, 03:26 PM   #2
yannis4ny
anyone?
Old 04-13-2014, 11:55 AM   #3
yannis4ny
Old 04-13-2014, 11:57 AM   #4
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Moved your thread into general e46. Where you had it before did not pertain to our cars in anyway.
Old 04-13-2014, 12:03 PM   #5
yannis4ny
Old 04-13-2014, 12:12 PM   #6
cityjohn
My Ride: 2001 M3
Looks like the piece between oil cap and valve cover
cityjohn is offline   Reply With Quote
Old 04-13-2014, 12:28 PM   #7
Solidjake
Zero. Leaks.
Solidjake's Avatar
Not flat enough and looks way different in my opinion
http://www.ecstuning.com/Search/Site...18528/ES18528/
Old 04-13-2014, 12:33 PM   #8
KaktusJaque
My Ride: 2003 325xi
put a quarter or something next to it to give us a size reference, but I havent seen anything like that in any of the DIYs I have done.
*KJ---Don't Believe Everything That You Think! *
Links
Buyers Guide
Nuts and Bolts
Behr Radiator Issue
Clean Your Dirty Wheels
2003 Touring 325 XiT (KJ's Ride)
2004 Coupe 325 Ci (Mrs. KJ's Ride)
KaktusJaque is offline   Reply With Quote
Old 04-13-2014, 12:47 PM   #9
Brandon002
My Ride: 01 330i Sport MtechI
Pretty sure that's not a part of your car. Could have been a piece of a tool or something someone dropped down there at some point.
I've worked on 100's of BMW's and never remember seeing anything like that before.
Brandon002 is offline   Reply With Quote
Old 04-13-2014, 12:48 PM   #10
KaktusJaque
My Ride: 2003 325xi
I was thinking that as well, but I dont have enough experience to make that statement.
Links
Buyers Guide
Nuts and Bolts
Behr Radiator Issue
Old 04-13-2014, 02:16 PM   #11
jdstrickland
My Ride: '94 325iC & '00 323i
It's one of those infamous "extra parts," that they put into cars but the car does not need. Is there a BMW logo on it anywhere?
Old 04-13-2014, 02:19 PM   #12
yoyomin
My Ride: 2002 330i
Oring inside the front control arm bushing
yoyomin is offline   Reply With Quote
Old 04-13-2014, 03:41 PM   #13
trj
My Ride: 325Ci
Exactly.
That grommet almost always falls out.
Old 04-13-2014, 04:21 PM   #14
yannis4ny
Thanks a lot for the replies. I recently did a CCV, ICV, DISA ovehaul so it might be a part from there, but I just cant figure out from where...Yes it has BMW sign on it with the numbers 2008 on one side and 33 on the other with an arrow in the middle. I did the lower control arm bushings about a year ago... I am pretty sure it is not coming from there...
I attached a new picture with a nickel next to it to approximate the real size...
Old 04-13-2014, 05:05 PM   #15
scottjoh
My Ride: '99 323i & '02 540i
Posts 12 and 13 already correctly answered your question. It is from the front control arm bushing!
Check out my post from 3 years ago with pictures.
http://forum.e46fanatics.com/showpost.php?p=12650250
scottjoh is offline   Reply With Quote
Old 04-13-2014, 05:06 PM   #16
Brandon002
It is from a control arm bushing, I have a set in the garage and just looked.
Old 04-13-2014, 05:19 PM   #17
yannis4ny
Thanks a lot duders! I will have to take a look at my bushings and hope it is not from the ones I installed last year! They are OEMs as well...Thanks again
Old 04-13-2014, 08:09 PM   #18
Blocked Out
My Ride: Imola 330i M-Sport
Thats a part of oe control arm bushes. Its used to limit the movement. You can easily keep driving the car as is . It doesnt really do much.
Depending on your mileage you should change the bushes like i said before , if the bushes are fine you can keep driving without that ring
Original BMW Teile ///
IMG_1725
Old 04-13-2014, 08:18 PM   #19
yannis4ny
I just check, this part is currently on both bushings. This probably got there when I was changing the last set a year ago. Thanks for your input!
