Old 04-15-2014, 07:27 AM   #1
NicenLoW
My Ride: E46 JB AA S/C
Need advice e46 m3 AA s/c
My car is throwing the rich bank 1 & 2 codes p0172/p0175. It doesn't seem like it's running to full potential either. It has the AA stage 1 gen 2 kit on it and I've changed maf, fuel filter, fuel pressure regulator, checked fuel pressure, cleaned icv, checked many times for vacuum leaks and replaced the vanos solenoid pack.
My symptoms are when cold hesitations, almost or does die sudden stops. When warm it idles very high when coming to sudden stops. MPgs obc are around 28mpg which that can't be right.
So should I take it to an Indy mechanic and let him use a smoke tester to check for vacuum leaks and do his diagnosis or take it to bimmerworld since I live 3mins away from there and have them to a dyno pull and look at everything? So my question is would this be a tune issue or a car issue lol.
E46 M3 AA S/C
E53 X5 3.0i
NicenLoW is offline   Reply With Quote
Old 04-15-2014, 09:49 AM   #2
NicenLoW
My codes scanned with peake tool.
AE-Mixture adaption cyls 1-3 (bank 1)
AF-Mixture adaption cyls 4-6 (bank 2)
90-Fuel control cyls 1-3 (bank 1)
91-Fuel Control cyls 4-6 (bank 2)
E46 M3 AA S/C
E53 X5 3.0i
Old 04-15-2014, 10:54 AM   #3
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
I get the af code once or twice a year and clear it and doesnt come back.
But never have gotten the 1b-90, nor the 1b-91 for Fuel Control. You should look into whats throwing that code.
"Player-haters turning bitch like they have vaginas ‘Cause we see them dollar signs and let the cash blind us.
Money'll brainwash you and leave your ass mindless..When snakes slither in the grass spineless.."
MachRc is offline   Reply With Quote
Old 04-15-2014, 12:12 PM   #4
Viral@ActiveAutowerke
Past Site Sponsor
My Ride: E46 M3
Hey There,
Just saw your thread and glad to see with our Stage 1 Gen 2 Kit on your E46 M3. With the larger injectors on the car, it will throw off the the MPG on the dash. I am going to send you a PM with list of information I need from you about this vehicle so I can point you in the right direction and get your car running properly.
Viral@ActiveAutowerke is offline   Reply With Quote
Old 04-15-2014, 12:46 PM   #5
NicenLoW
Thank you for the response!
E46 M3 AA S/C
E53 X5 3.0i
