Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 54 votes, 5.00 average. Display Modes
Old 07-28-2014, 01:19 PM   #41
tprgreen
My Ride: E46
J03SK1
go to home screen
press android icon
press disk icon.
tprgreen is offline   Reply With Quote
Old 07-28-2014, 02:02 PM   #42
J03SK1
My Ride: E46 M3
Sorry I didn't explain my problem properly. Every time I try load up a vid I get a message saying "it's not safe to drive whist watching videos blah blah"
J03SK1 is offline   Reply With Quote
Old 07-28-2014, 08:25 PM   #43
SKR7
My Ride: E46 MY04.5 SMG M3
the message would be right then.
///M
2004 E46 M3
SKR7 is offline   Reply With Quote
Old 07-29-2014, 04:31 PM   #44
J03SK1
My Ride: E46 M3
Thanks for your pointless comment. I want to know how to play a video whilst driving so the other people in the car can watch
Old 07-30-2014, 01:12 PM   #45
raichean
My Ride: 2004 e46 M3 cabrio
There is a check box in the settings that will suppress that.. cant remember it off the top of my head atm where, but its there.
raichean is offline   Reply With Quote
Old 07-30-2014, 01:13 PM   #46
raichean
Originally Posted by tprgreen View Post
i am having issues loading "scout navigation" the option sais its not compatible with this device? update needed?
I get that from some apps.. make sure you have updated the deck to the latest public build, and check again. If not, definitely give that feedback to Tommy about the app.
Old 08-15-2014, 12:38 PM   #47
deaM3
My Ride: 2006 M3
I recently installed the avin-2 and having this issue where the next day my car wont start and it seems that the battery is drained. I need to jump it to get it started. Now when I revert back to stock radio(business cd), i never have this issue. I already went to autozone and my battery checks out at 12.7v so I am wondering if there are any differences with the harnesses on the 06 M3 thats causing this drain. I reached out to Tommy and he said this was the first time he is hearing this issue. Any ideas would be appreciated. Thanks.
deaM3 is offline   Reply With Quote
Old 08-15-2014, 12:47 PM   #48
tprgreen
My Ride: E46
even if your battery test good without load it can still have issues. i do know that the operating power of the avin is more because it has bigger amp inside. many batteries can have issues under load and loose capacity very quickly. how old is your car battery? if it is over 2 years i would try replacing it with new one after it has been fully charged to 100%soc. i am an electrical engineer specialty is power delivery so i have much exp in this area. hope this helps
Old 08-28-2014, 12:33 AM   #49
d12
My Ride: 325 Ci
http://www.jandtdistributing.com/pag...allation-setup
"Dynavin Android Setup" describes how to get to the toggle for this.
d12 is offline   Reply With Quote
Old 09-13-2014, 03:51 PM   #50
Richy759
My Ride: E39 350i sport touri
Originally Posted by alirz View Post
Please urgent help needed.
I just received my avant 2 unit for my 2003 m3 coupe. I've plugged everything in but I have no sound from any source at all...I'm replacing my stock business non navigation radio.
Just to confirm I've plugged the bracket and the Ibus connector to the back for the avant. I also have another bracket(the one with ILL wire) that came with the avant 2 but I guess thats for radios with a different pin layout(I'm not using that one)?
I'm also not using the plug that has various audio in/out RCA plugs. I assume that for after market amps and stuff?
The bracket that is currently hooked in the back of the unit has a wire for REVERSE, PARKING, AMP...and maybe one other wire...those are currently not used...
The unit turns on. I have a media car in the slot and I can see my music.
If it seems everything has been installed good then how come I have zero sound from any inputs, radio, media SD, Bluetooth etc... Please help....
I appear to have a similar problem. Can I ask what the solution was?
Richard
Richy759 is offline   Reply With Quote
Old 09-19-2014, 03:44 AM   #51
julle
My Ride: BMW 330Ci, 2003
Hi All.
I have a BMW 330Ci from 2003 (facelift) and just bought the Avin Avant 2 unit. Looking really forward to mount it, and I really appreciate these tutorials! One question though; Do I really need to remove the rear badge in order to install a rear camera? The camera I have is to be mounted in the license plate holder, and still use the same original bulb. If so, I'm not really sure how to remove the badge...
Is it glued on?
If so, then how do I mount it properly again??
Thanks!
Alex.
julle is offline   Reply With Quote
Old 09-19-2014, 08:31 AM   #52
raichean
Hey Alex.. I have the guide posted up for the camera install. Assuming your trunk and camera model is the same, then yes the rear badge has to come off to get to a mounting screw. There is a ring of sticky adhesive that secures it and in my case, was still tacky when I stuck it back on.
Check the camera DIY and don't hesitate to shout if you need help.
Old 09-19-2014, 03:14 PM   #53
julle
Hi raichean.
First off, thanks for your guides, and then thanks for your answer above.
Quick question: Under the badge, you'll find a torx screw. What exactly does this screw hold together?
Is it really necessary to unmount the entire socket (the one with the handle and the two number plate lights)?
Thanks.
Old 09-19-2014, 03:18 PM   #54
raichean
Originally Posted by julle View Post
Hi raichean.
Thanks.
Howdy!
So that torx is one of the series that holds that trim piece on, so if taking the whole thing off, it will need to come off. That said, I think in theory it might be possible to install the camera, route the wires back through the trunk and do the install without taking the trim off. For make take, it wasn't possible for me, and pulling those torx and pulling the whole trim off made it 1,000x easier. I would take it to my workbench and do the work there, including shaping the socket and camera housing to fit much more easily.
Pulling the trim is quite easy.
Old 09-19-2014, 04:31 PM   #55
julle
Thanks again for your quick response!
So I basically just use some kind of trim remover tool (plastic), and gently stick it under the the badge and pull?
Sorry for keep asking
Old 09-19-2014, 04:33 PM   #56
raichean
Yes... I actually had some heavy fishing line so ran that between the badge and trim to help pull through that seal first, but yes. Gently pry up with a plastic trim tool is best.
Old 09-19-2014, 05:14 PM   #57
ELCID86
My Ride: 2004 330i (ZHP) x2
Dental floss can help too.
iPhone and BimmerApp
Shawn in VA (USA).
- Shawn's 2004 IR/Alc. w/6MT ZHP (1/351 built)- http://bit.ly/1nhx4gk
- 2004 OB/Sand w/6MT ZHP (1/25 built)- (sold)
- 2004 OB/NB w/AT ZHP- (sold)
ELCID86 is offline   Reply With Quote
Old 09-19-2014, 05:24 PM   #58
julle
Ahh, great tip with the fishing line to remove the badge.
Okay, last couple of questions, and then I think I have pluck up courage to actually begin installing :-)
For the reverse camera wiring, I believe I know how to do, but can you verify my pictures: Basically, all I need to get confirmed is that the "extra" wire needs to be connected to the "reverse wire" of the Avant 2 unit?
I also looked though all the wires that comes with the Avant 2 unit, and that led to more questions:
What are AMP CON and PARKING used for?
- I have HK audio, so I guess I have a wire that simple should go to the AMP CON?
- Parking?? No clue. Do I need to shortcut it or something in order to watch videos while having the car in Drive mode?
- And finally: Does it matter which of the two USB inputs I hook up the USB modem to?
ID:	574263   Click image for larger version
ID:	574264   Click image for larger version
Old 09-20-2014, 04:54 AM   #59
julle
Hi All.
With some great support from Tommy (from Avin) I have now figured out the wires:
Reverse = connects to the reverse light 12v power wire. When car is put in reverse the unit will detect it by this wire and put the unit into backup camera mode (just like my picture above).
Parking = connects to parking wire of the car. Allows you to watch video in motion. This is optional because there is also a option to enable video in motion in the settings menu. Parking wire is not really necessary.
Amp com = trigger to power on external amplifier.
I have the original Harman Kardon speaker system, including a sub, and asked Tommy if I should use this wire then. He believes that I do not have an extra amp for this system, hence I should not use it.
USB Modem: You can plug the usb modem into either of the usb ports it will work the same.
Old 10-31-2014, 03:07 PM   #60
gemjam4u
My Ride: 01 BM-330i Auto-Euro
Question Does avant2 support inline alpine 6cd changer..?
Does avant 2 support inline alpine 6cd changer..?
Also how about the anti glare of the screen..?
And does the navigation system always requires an internet connection to work...? or will it work like nav-sat like the oem sat systems..?
gemjam4u is offline   Reply With Quote
