Maximum PSI Stage 2 Turbo Build | SMGII | BW 3.5" Race | Zima Motorsports - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 25 votes, 5.00 average. Display Modes
Old 05-06-2014, 12:23 AM   #41
BrianSpilner
My Ride: Max PSI Stage 2
Originally Posted by BGOC View Post
WOW! so basically you are making 490whp on 6-7 psi not considering that overboost situation? You will make 500whp+ easy at 9pounds
Yes, you are correct
Follow My Builds: Max PSI Stage 2 E46 M3 Turbo Build | 1972 2002 Restomod Build
2004 BMW E46 ///M3 | Maximum PSI Stage 2 Turbo | SMGII | Non-Catted | 711rwhp | 578rwtq
BrianSpilner is offline   Reply With Quote
Old 05-06-2014, 02:12 AM   #42
Commanderwiggin
My Ride: 1000rwhp Turbo M3
Ya Kris you definitely need to increase your gain settings on your boost controller.
Also what is your wideband reading for AFR after 5k on a pull? I'm reading that graph as being > 12:1
Commanderwiggin is online now   Reply With Quote
Old 05-06-2014, 02:23 PM   #43
XKR
My Ride: 2001 M3 Convertible
How does your exhaust sound now with the turbo? Does it still have a lot of drone? Also, do you feel like you had more low end power with the supercharger instead of the turbo?
~SGT catless headers|Full BW 3.5" Resonated Race Exhaust w/ diffuser | Epic Motorsports Race Tune | BAC Filter | BW Intake Elbow
~Tein S-Tech Lowering Springs | Sebion CF hood | CF Kidneys | ‹mnitiza Predator Orion V4
XKR is offline   Reply With Quote
Old 05-06-2014, 04:50 PM   #44
BrianSpilner
The issue will be worked out this week. It's a simple fix. The AFR is at 12:4 at 5k and goes to 11:25 at 8k. So mid 12's for AFR throughout the RPM band.
The turbo is essentially a resonator. It kills a lot of the drone and you'd swear you're running an OEM-like system until you really get on it. It sounds loud from the outside, though. With the cutout open, it's stupid loud and droney haha.
The feeling is better than a supercharger mainly because of the HUGE torque gain. The car just keeps pulling and never wants to stop whereas with a supercharger, you can feel it working all it's might to keep power consistent above 6k or so. I should have gone turbo ages ago.
Old 05-06-2014, 04:58 PM   #45
Commanderwiggin
I think you should probably have a closer look at the AFR's...12.4 is pretty lean.
Old 05-06-2014, 05:03 PM   #46
BrianSpilner
I sent all the info to Mike and he said everything looks normal. The numbers should balance out after I get this boost issue sorted. Where do you think the AFR's should be?
Also (I forgot to mention this), I did pulls on a 1/4 tank. These cars are known to suck air with anything below 1/2 full. This could be the cause of running lean.
Old 05-06-2014, 05:43 PM   #47
Commanderwiggin
I personally run between 10.5-11.0
I know 11.5 is usually the guidline but 12's...that's getting sketchy.
Old 05-06-2014, 06:42 PM   #48
mdrobnak
My Ride: 04 330i SMG TT STG1
I see nobody else has given the explanation in here, so...
With respect to the BOV location, you are correct it cannot be after the MAF. This because of the same reason you can't run a BOV at all on a stock setup - the MAF has already accounted for the air which has passed by it, which has now been dumped into the atmosphere. This would cause a severe rich condition for a period after you've closed the throttle.
As far as AFR values, this entirely depends upon how aggressive the timing table is. 10.5:1 will not save you if the timing is too aggressive. 11.5 - 12.3 is safe, with 11s being on the more conservative side. In my opinion the setup will be fine once the overboost situation is resolved.
-Matt
2004 330i with Technique Tuning Stage 1 Kit, UUC Twin Disc Clutch + FW Kit, Walbro 400 Fuel Pump, Aeromotive FPR, Modified Return Lines, E36 Fuel Filter, Ethanol Content Sensor, 550i Clutch Actuator, Lengthened actuator rod, modified exhaust, and FX-R projectors.
93 Octane - 8.5 PSI : 309RWHP on a Superflow / 3XXRWHP on a DynoJet
E85 - ? PSI : ???RWHP on a DynoJet
First SSG MoTeC M150 Powered 330
mdrobnak is offline   Reply With Quote
Old 05-06-2014, 10:53 PM   #49
gt35rm3
My Ride: Turbo E36 M3, E92 M3
12.3 is fine at that boost level.
Wait, have you felt the power of race gas yet?!
gt35rm3 is offline   Reply With Quote
Old 05-07-2014, 07:22 AM   #50
BrianSpilner
I will this weekend
Dyno pulls will be done soon I promise and I'll update this thread accordingly.
Old 05-07-2014, 07:43 AM   #51
gt35rm3
Ohh man, I'm excited for you.
Old 05-07-2014, 08:04 PM   #52
mike@maximumpsi
My Ride: 02M3T
I talked to Kris about the boost controller settings. 11 psi is too much boost on pump gas, however it will be in check with the eboost tweaking.
Regarding the afr, we target 11.7 in the midrange and it will get into the low 12's at redline. There are a bunch of things that could affect afr readings on a chassis Dyno. When you have a open exhaust cutout upstream of the Dyno sensor you will have a skewed afr reading at the tailpipe. How old is the Dyno sensor? What is the probe setup? The best bet would be to verify the in-car wideband on the street. Have a buddy video the boost, afr, and rpm.
02 M3 - Maximum PSI S2 turbo kit - 9.74@145.99, stock motor, stock ECU, first in the 9's
97 M3 - Maximum PSI turbocharged - 8.94@164.33, stock ECU, first in the 9's, first in the 8's
16 M3 - Maximum PSI full bolt ons - 10.27@137, quickest in the US
BMW SOB's turbo E30 - 8.72@158.39
Maximum PSI - Home of the quickest BMW's in the US
Click here for E46Fanatics 1/4 mile standings
Follow us on Facebook and Instagram!
mike@maximumpsi is offline   Reply With Quote
Old 05-07-2014, 08:07 PM   #53
mike@maximumpsi
My Ride: 02M3T
Another thing worth mentioning: yes, the car picked up big power with the cutout open, but the boost went up as well. If boost is equal I bet it would be no difference in power over your 3.5" race exhaust, especially at pump gas boost levels. The nice thing is that at 9psi the car should be at 500+.
Old 05-07-2014, 08:10 PM   #54
BrianSpilner
The dyno sensor works fine on other cars, so that isn't the issue. The sensor gets placed into the bung where the AFR gauge gets it's readings from. This is before the dump valve.
My AEM AFR sensor took a crap on me, so I am waiting for that to be fixed.
I am super excited to be above 500rwhp on pump gas!!! Maybe even ~20lbs+ in torque too?
Old 05-08-2014, 11:24 AM   #55
BGOC
My Ride: M3
Just received my stage 2 SMG the other day. The car has not stalled on me once. Once car is up to operating temp the idle stays rock solid. Until warm up I get loopy idle for a 1 min or so until vehicle finds its right calibration. I have the SMG with a UUC Twin disc organic, shifts are extremely fast and smooth almost stock like. As far as AFRs under boost I am around 12 or below I have never seen it go above 12.5. Will be putting in some race gas to see how that feels this weekend. Maximum PSI is the way to go.
BGOC is offline   Reply With Quote
Old 05-08-2014, 09:05 PM   #56
BrianSpilner
Congratulations!!! How is the chatter in 1st and 2nd gear from a stop? I am thinking about getting rid of my HPF Stage 2 clutch cause it's super annoying.
Old 05-08-2014, 09:47 PM   #57
Rob43
My Ride: 03 331Ci 5spd R1200R
What do you mean by "chatter in 1st & 2nd gear from a stop" ? This sounds different from the typical "chatter" while sitting at a traffic light with the A/C on, could you elaborate.
SUMMIT POINT WV 1:24:229 SCCA
Old 05-08-2014, 10:03 PM   #58
BrianSpilner
Like when you're starting off from a stop or cruising slowly through a parking lot at a low RPM, does the clutch feel sticky or that it isn't engaging quickly? Basically, does it feel different than OEM?
Old 05-08-2014, 10:20 PM   #59
Rob43
I ask this question thinking I must be foolish for even asking it: You did remove that little "piece" in the clutch line ? I think it's called a clutch delay valve (CDV).
Anyway I've been running the UUC Twin Organic for a few years now, there's very little, to almost no "chatter" while idling at a light. I do run the UUC recommended trans fluid "cocktail" blend, which helps that. The chatter you speak of in 1st & 2nd gear, well I've never experienced that. I will say that the Twin Organic is firmer than my stock clutch feel, but keep in mind I'm comparing it to a Non M 330Ci. I'd recommend this clutch to you without any hesitation, I'm certain Mike at Max. PSI runs them in a few of his cars.
Old 05-09-2014, 12:49 AM   #60
BGOC
My Ride: M3
Thanks, no feels great for me. Almost OEM like except it grabs firmer from stop.
e46, m3, maximum, psi, turbo
