Old 06-04-2014, 04:11 AM   #21
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
it makes you look like a spaceship and is amazing light - you can also code the lighting to have the center lights on as high beams with the bi-xenon high beams and the fogs
you would have 6 intense lights on with high beams
/_________\
O==[][]==O
Old 06-04-2014, 04:18 AM   #22
1`
Banned User
My Ride: 330i
Originally Posted by 330i ZHP View Post
do you have your car coded to have the fogs on with high beams?
I don't have it coded, but I do have the OBD to USD cable and software. I haven't delved into it yet. I want to turn off the parking lights with the low beams on too.
1` is offline   Reply With Quote
Old 07-16-2014, 06:10 PM   #23
330i ZHP
330i ZHP's Avatar
This is an evening of looking at the "problem" and about ten minutes of trimming plastic and metal heat sink material not needed
/_________\
O==[][]==O
Old 07-16-2014, 09:14 PM   #24
travie46
My Ride: 02 325i
Nice and looks very clean. I'll start the retrofit, but do you know if the fogs can be baked to be opened or i will need the dremel tool?
What happens in Vegas, stays in Vegas
travie46 is offline   Reply With Quote
Old 07-16-2014, 09:22 PM   #25
330i ZHP
330i ZHP's Avatar
I have removed two ridges inside the fog housing. And trimmed the heat sinks.
All one unit using factory clips and seals.
/_________\
O==[][]==O
Old 07-16-2014, 09:23 PM   #26
330i ZHP
330i ZHP's Avatar
I only had to trim the very edges of the heat sinks and then round their profiles to match the original lens
The back of the fog just clips on. No heating required
/_________\
O==[][]==O
Old 07-16-2014, 10:10 PM   #27
330i ZHP
330i ZHP's Avatar
/_________\
O==[][]==O
Old 07-17-2014, 04:44 PM   #28
travie46
My Ride: 02 325i
I'll try to do the same. I hope everything goes well.
Old 07-19-2014, 01:03 AM   #29
1`
Banned User
My Ride: 330i
smart, what did you use to trim it?
Old 07-19-2014, 08:39 PM   #30
330i ZHP
330i ZHP's Avatar
dremel and cut off wheel
what do you think of the lighting?
/_________\
O==[][]==O
Old 07-19-2014, 08:45 PM   #31
330i ZHP
330i ZHP's Avatar
I find the lighting to look nice in the fogs - but the light output is very disappointing. The 9006 xenon retro is much brighter (but also often too bright for other drivers) but I am tired of dealing with ballasts, igniters and/or bulbs not working (no matter what brand/vendor)
soooo, more light xenon or reliable with led...your choice
/_________\
O==[][]==O
Old 08-04-2014, 10:35 PM   #32
1`
Banned User
My Ride: 330i
I think the output is fine; probably because frankly I still haven't had any need to actually turn them on yet (while on the road I mean; I'm turned them on just to test them).
