Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > UK
UK
Have you seen another BMW while driving around in your area? Find other members from your area in the E46Fanatics Garage HERE
Old 05-08-2014, 05:15 PM   #1
jammy87
My Ride: looking for coupe 46
OBD FAULT CODE READER. (which one)
Hi. I apologise in advance if this is in the wrong area.*
I have been looking at getting a fault code reader as they seem to be pretty cheap for a diy kind of thing.*
Iv been looking on ebay and there seems to ne so many ranging from 20-150.*
Could anyone who knows a bit more about this please give me some advice. Or maybe a link to one that i should buy, doesnt have to be anything amazing only going to be using ot on my own car as and when.*
Cheers
jammy87 is offline   Reply With Quote
Old 05-08-2014, 05:17 PM   #2
VALMONT
The De46vil's Army
VALMONT's Avatar
My Ride: 325Ci, Outback
Send a message via AIM to VALMONT Send a message via MSN to VALMONT
I have this, I like it, no complaints
VALMONT is offline   Reply With Quote
Old 05-09-2014, 12:38 AM   #3
jammy87
Been looking about and the c110 scanner looks pretty good, and its does well with bmw cars from what iv read. Any one had any experience with one?
Old 05-16-2014, 05:50 AM   #4
ashE46
My Ride: e46 330D
if your not set on getting a portable reader id recommend the p.a soft bmw scanner, not only does it read the Engine DME like most generic OBD scanners but it also works for all other modules e.g ABS, Airbag, Instrument cluster e.t.c the list is endless and it also does coding but Best of all its cheap.
ashE46 is offline   Reply With Quote
Old 05-17-2014, 03:53 AM   #5
hub_one
Bump
hub_one is offline   Reply With Quote
Old 01-21-2015, 07:11 AM   #6
Kuro
My Ride: 2004 E46 M3
I bought a USB cable from eBay for about 20 that came with all of the BMW official dealer diagnostic and coding software as well as the workshop manuals. Nothing beats OEM (kinda)
Kuro is offline   Reply With Quote
Old 02-11-2015, 03:37 PM   #7
stuartlongshanks
My Ride: 335i
I've got a c110 . Been a good reader so far no probs and cheap enough
stuartlongshanks is offline   Reply With Quote
Old 09-01-2015, 08:28 AM   #8
CHEW46
My Ride: 2000 323i
I have the C110 V3.9. It works very well however, for whatever reason it won't ready anything from the body. I keep getting an error code. It reads everything else just fine. Also, the update software is faulty. The program itself just freezes.
CHEW46 is offline   Reply With Quote
Old 02-13-2016, 05:07 PM   #9
Bandit88
My Ride: E46 328ci
E46 328ci scanner
my C110 arrived today and its great, already saved me a small fortune and is the only one ive found that works properly, very cheap online
Bandit88 is offline   Reply With Quote
Old 02-19-2016, 02:07 PM   #10
jcjdavis1
My Ride: 323ise 1999 saloon
Hi, you don't say what year/model you have, on some early models the OBD port is in the engine bay and you need an extra adaptor. Jim
The older I get the wrong bit gets stiff!!
jcjdavis1 is offline   Reply With Quote
Old 02-19-2016, 02:34 PM   #11
Bandit88
My Ride: E46 328ci
E46 328ci scanner
I have a 1999 328ci (manual) which has both connectors. The C110 works in the OBD11 port in the drivers footwell to the left of the steering column so no adapter is needed.
The first time I used mine it found O2 sensor No1 bank 2 heater circuit fault and an intermittent misfire cyl 5, both were fixed for less than the cost of plugging it in at a garage.
Hope this helps
Old 02-25-2016, 06:56 AM   #12
Bandit88
My Ride: E46 328ci
Hi
sorry forgot to say, on an early E46 like mine the C110 will only give engine info through the OBD 2 port. For ABS etc you need to use the port under the bonnet with a 20-16 pin adaptor.
