Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > UK
UK
Have you seen another BMW while driving around in your area? Find other members from your area in the E46Fanatics Garage HERE
Old 05-24-2014, 07:32 AM   #1
annnnt1
Hiii to all the uk bmw 3 series owners!!!
Hello everyone .. Right I jst purchased a bmw about a week ago what a lovely car they Are !!! Previously I owned a mg zr and what aload of poo that was !! I been looking on here since I got the car to get ideas what to do to it and keep up maintanence for it .. It's a 318 I 2.0 litre petrol ... It has service history and 70 thousand miles in the clock .. It didn't creak or nuffin ! I'm thinking of servicing it with the help of my cousin .. Who is a mechanic .. I'm gnna get a new water pump from euro car parts are they any good for parts?? Thermostat ? And what are the belts that work the water pump should I replace them ? What are they called ? And change air filter and plugs .. Anything else I can change aswell u guys can think off ?? Thanks for ur time reading this cheers from ant in dirtford Kent xClick image for larger version
annnnt1 is offline   Reply With Quote
Old 05-30-2014, 09:56 AM   #2
Shaun1970
My Ride: 318i SE 2000
Send a message via MSN to Shaun1970
Welcome to the forum mate, I use Euro for some parts, have used their water pump in last change and thermostat and that's been good so far...touch wood! The belt you are looking for is the "Drive Belt" Of course if your changing water pump i giess you will do a coolant change at same time! Probably worth Oil and Filter change too, unless you know last change date. Have fun
Shaun1970 is offline   Reply With Quote
Old 05-30-2014, 12:46 PM   #3
annnnt1
Hey thanks for the reply mate .. Yeh the oil has already been done at 68 thousand miles so dnt need to do that .. So it's just one belt that drives the water pump ? What bmw have u got ?? The thermostat is baught in the housing aswell ? Isit worth replacing the expansion tank ? I been doing a lot of reading on the e46 thanks for ur time replying mate
Old 05-31-2014, 03:17 AM   #4
Shaun1970
Real OEM shows one, for yours see here if you take a peak you will be able to determine what you need, mine shows two, but not looked in a while, also check tensioners just to be on the safe side.
That's correct thermostat comes with housing, its a all in one unit, expansion tank would be a good swap out if your doing a full coolant swap too, yes they are prone to just failing, mine did recently a 5 inch hairline crack was found in it, and that had only been on car 8 months, however if your going down that road, I personally while coolant out would check all hoses too, save redoing it 2-3 months down the line if issues, but your eradicating them before they appear if you get my drift Coolant is the biggest thing on these cars and tons and tons of posts about it, Pre-emptive strike saves stress lol
I have the 318i 1.9 2000 model (pre face) and pretty much swapped a lot out now HG/WP/Tensioners/Rad/Thermo/Timing/Tappets/Hoses and so on the list is endless
Old 05-31-2014, 10:31 AM   #5
annnnt1
Thanks for the reply mate u got any pics of ur car.? I noticed mine sputters abit like start up in the morning .. U put it into first kinda dies then kicks in if u no wot I mean .. No warning lights come up could this b the fuel filter ?
Old 05-31-2014, 05:14 PM   #6
Shaun1970
I would try spark plugs first if a little sputter, fuel would be more under load in my thinking, not 100% sure though. Start at cheapest option and work through.
Yeah here is a couple of mine.
ID:	560354   Click image for larger version
ID:	560355   Click image for larger version
Old 06-01-2014, 04:18 AM   #7
annnnt1
That's a nice motor mate how fast u ad out of it ? Wots ur next motor gonna b ?
Old 06-01-2014, 05:04 AM   #8
annnnt1
What oil do u use
Old 06-02-2014, 02:07 PM   #9
Shaun1970
For speed its pants, im used to the 2.5 V6 i had before (Mondeo) my next though is a 330D Tourer which i am currently looking for, have a little one and need space lol. On last oil change i used 10/40 as the 5/30 seemed to just burn like hell and now runs a lot smother but she has 128k on the clock, with yours being 70k i would stick to the recommended for now mate.
Old 06-02-2014, 02:33 PM   #10
annnnt1
I gt some castrol edge .. Cost me 47
dooming pound .. Yeh I got two so needed a decent car .. Was using. A fiat pinto p reg .. Av u ad the timing chain Changed at all? U do most work ur self ?
Old 06-03-2014, 04:03 AM   #11
Shaun1970
Just had the timing chain tensioner changed recently, i do some bits myself, however running a business I don't get time to fiddle so the more intricate work goes to a friend who is a mechanic.
Old 06-03-2014, 04:31 AM   #12
annnnt1
What business u run?
Old 06-03-2014, 04:52 AM   #13
Shaun1970
An IT and Consultancy business mate
Old 06-03-2014, 06:55 AM   #14
annnnt1
Kool thanks for the help mate
Old 06-03-2014, 11:57 AM   #15
annnnt1
RClick image for larger version
ID:	560681 do u no how to get these off ?
Old 06-07-2014, 04:24 PM   #16
Shaun1970
Look from 3.20 on this mate they are pretty simple to get off 3 Bolts i think!
Old 06-07-2014, 05:17 PM   #17
annnnt1
Thank u very much for that that helps alot
