Go Back   E46Fanatics > Everything Else > The Off-Topic > Gun Talk
Gun Talk
Are you a gun fanatic as well? If so, you'll want to talk to other owners about what you own in this forum.
Old 05-28-2014, 08:21 PM   #1
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
Picatinny vs Weaver rail system?
What are the differences? Is one used for scopes and the other used just for accessories? Or are they used for both and one favored over the other?
Old 05-28-2014, 08:26 PM   #2
Serbonze
Master of his domain.
My Ride: My wife
Short answer, the grooves. Very detailed answer:
http://www.brownells.com/.aspx/lid=1...he_Difference_
What are the differences between the “Picatinny” and the “Weaver” systems? The profile of the two systems is virtually identical. Depending on the quality of the machining done by the manufacturer, the two systems should be indistinguishable from the profile. The key difference lies in the placement of the recoil grooves and with width of the grooves. MIL-STD-1913 (Picatinny) grooves are .206” wide and have a center-to-center width of .394”. The placement of these grooves has to be consistent in order for it to be a true “Picatinny” MIL-STD system. Weaver systems have a .180” width of recoil groove and are not necessarily consistent in a center-to-center measurement from one groove to the next. In many instances, a Weaver system has a specific application that it is machined for, so interchangeability is not necessarily an issue. A MIL-STD-1913 system must adhere to the specifications listed above in order for it to be considered MIL-STD, since the military desires uniformity in the recoil grooves to allow for different systems to be mounted on the weapon with no concern for compatibility.
Now, what does this mean to you? Boiled down, it means that accessories designed for a Weaver system will, in most cases, fit on a “Picatinny” system. The reverse, however, is probably not the case. Due to the larger recoil groove, “Picatinny” accessories will not fit a Weaver system. There are, of course, exceptions to every rule, but for a good rule-of-thumb, “Picatinny” won’t fit Weaver, but Weaver will fit “Picatinny”.
Serbonze is offline   Reply With Quote
Old 05-28-2014, 08:27 PM   #3
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
Perfect, that's what I needed. Is one favored over the other as far as an industry standard or is it more up to personal preference? Or more importantly, will an accessory designed to work with one work with the other?"
edit:
That settles that
Old 05-28-2014, 08:36 PM   #4
Reedo302
Reedo302's Avatar
My Ride: F30 328i M Sport
If you have a choice between the two, get Picatinny. Picatinny M1913 STANAG is an international standard. Weaver is not. Nearly all accessories now are designed for Picatinny mounting. If the question relates to scope bases, you most definitely want Picatinny due to the abundance of options available. The weaver system is all but dead at this point, and typically are only sold/mounted on low end hunting rifles.
DINAN3 F30 328i M Sport
DinanTronics Stage 1
Dinan Free Flow Black Tip Stainless Exhaust
Dinan Lowering Springs and Bumpstops
Dinan 20" Black Performance Wheels
Gunfighter Training Development and Evaluation
AR15/AR10 Armorer/Advanced Armorer
Glock Armorer
Gunfighter Training YouTube Channel
Reedo302 is offline   Reply With Quote
Old 05-28-2014, 08:54 PM   #5
cowmoo32
cowmoo32's Avatar
My Ride: Yukon
It's for some design work I'm doing. I've seen the rail systems before but had no clue about a standard or how exactly they function; I've always shot my friends' AR's, still don't own one yet.
