Engine & Performance
Old 05-29-2014, 10:57 AM   #1
raichean
My Ride: 2004 e46 M3 cabrio
FS: aFe Magnum Force Cold air intake stage 1 plus force tube
****SOLD*****
Hey all!
Considering this is specifically for the M3, I thought I would post this here. I would prefer to sell in the PacNW and in person but will consider shipping for the right folks.
I am working with AFE to do full install guides (now available) and reviews (posted soon) for the S1 and S2 kits. This is the best instant gratification, bang for the buck upgrade I have done to my car yet!
This S1 kit includes the magnum force tube that coverts it into the full S2 stats and the Pro 5 R oiled filter.
This was installed for less than 72 hours in my 2004 M3 for demonstration and documentation purposes and then removed back into original packaging.
S1 kit - $519.75
Tube upgrade - $103
Will sell both for *EDIT* $400 plus shipping if applicable
FS: Magnum FORCE Stage-1 PRO 5R Intake System; BMW M3 (E46) 01-07 L6-3.2L 54-10461
http://afepower.com/shop/details_new...2L&&brandID=52
Magnum FORCE Torque Booster Tube; BMW M3 (E46) 01-07 L6-3.2L (Blk) 54-10469-B
http://afepower.com/shop/details_new...2L&&brandID=18
Full description:
This air intake system produces 11 max horsepower, 10lbs. x ft. torque and out-flowed the factory intake by 70%. Includes a durable 16-gauge, powder-coated heat shield; this air intake system features a washable/reusable conical air filter. This intake system incorporates a unique 3-angle filter adaptor that directs the air transition into the intake tract for better performance. The one-piece heat shield requires no assembly and the filter is constructed with 100% polyurethane for long life and multiple cleaning cycles.
5-1/2" Conical Filter with Inverted Top: This intake utilizes a huge, 5-1/2" conical Pro 5R performance air filter with inverted top for maximum flow. This 5-layer progressive, oiled cotton gauze air filter provides maximum flow for increased horsepower and torque.
One-Piece Filter Housing: The air filter is housed in a one-piece, black powdercoated 16-gauge heat shield that keeps warm engine air out for maximum performance. This one-piece heat shield uses factory mounting locations and comes with all hardware for a hassle-free installation.
Brushed Clear Coat Cover: A Brushed clear coat anodized aluminum top is used to provide a clean, elegant style to your E46 engine compartment.
Billet Aluminum 3-Angle Adaptor: A precision machined, billet aluminum 3-angle adaptor is used to speed up the air flow for improved performance and throttle response.
This intake is 50-state legal for 2001-2005 models (CARB E.O Number D-550-2).
Magnum Force Torque Booster Tube:
aFe Power is now offering a hi-temp silicone Magnum Force Torque Booster Tube for the 2001-2007 BMW (E46) M3 L6-3.2L. This torque booster tube is the perfect upgrade to convert the Stage 1 intake system (P/N: 51/54-10461) into a Stage 2 intake system. The torque booster tube can also be used to replace the factory intake elbow on the OE air intake system.
3-Ply Reinforced Black Silicone: Constructed of 3-ply reinforced silicone, this torque boost tube is resistant to cracking and hi-temp conditions. With a smooth interior surface, this torque booster tube is engineered to increase HP, Torque & air flow by reducing turbulence.
Hassle-Free Installation: This torque booster tube connects the billet 3-angle adaptor on the Stage 1 system to the intake manifold. With two stainless steel clamps, this part is a quick and easy bolt-on, requiring no cutting or drilling on OEM parts for hassle-free installation.
*Note: This Torque Booster Tube is not CARB exempt at this time and is not legal for sale in California or use on vehicles registered with the California Department of Motor Vehicles.
DPP_0054 by handaar, on Flickr
raichean is offline   Reply With Quote
Old 05-29-2014, 09:41 PM   #2
Teslazerok
My Ride: 2003 M3 6SPD
You must be some installer!
Originally Posted by svtmike
Your TL is an eminently replaceable mass production inaninimate object that doesn't give a sh*t about you.
Teslazerok is offline   Reply With Quote
Old 05-29-2014, 09:50 PM   #3
raichean
I have been and am working with aFe directly doing product install guides and reviews. The S1 kit plus upgrades was installed into my car for that purpose and then removed after several days, to make way for the full S2 kit.
Make more sense now?
Old 05-30-2014, 02:41 AM   #4
iansevilla
My Ride: 2004 M3 Coupe
That won't pass SMOG only on visual. right....but if you know someone who does smog and will pass visually. Is it ok to have one?
iansevilla is offline   Reply With Quote
Old 05-30-2014, 08:46 AM   #5
raichean
According to aFe, it will pass emissions testing:
Old 06-11-2014, 03:36 PM   #6
raichean
I will be at the PacNW BMW CCA event this weekend (Dyno and BBQ) and this kit is still available. I would consider helping install on the spot if someone was interested.
Thanks.
Old 09-01-2014, 02:26 AM   #9
iansevilla
Got one for $225...:-)
afe power, cai, cold air intake
