Old 06-02-2014, 11:18 PM   #1
rplogue7
My Ride: 2001 325ci vert
buying an Intake... opinions wanted!!!
I have a 2001 bmw e46 325ci and I want a little kick boost. intakes look really easy to install so I was just wondering what you guys have, your experiences with your intake(s) and which one I should buy/install. keep in mind that I'm only 16 so price is definitely an effective factor In this search. won't go over $250. any suggestions/opinions are appreciated. thanks guys
2001 325ci vert
rplogue7 is offline   Reply With Quote
Old 06-02-2014, 11:43 PM   #2
unevolved
My Ride: 2003 325i
You will gain nothing but noise. Your ECU will not adapt to the increased (marginally) air flow.
If you're 16, let's face it, you're more worried about how the car looks and sounds. Let's just make sure it's safe to drive. You're going to get bombarded with haters on here (it's mostly in fun), but if you've got any specific questions, feel free to PM me.
In a bacon and egg sandwich, the chicken is involved, but the pig is committed. Be that pig.
unevolved is offline   Reply With Quote
Old 06-02-2014, 11:44 PM   #3
[USMC]Skywalker
My Ride: 2004 330i
trust me on this one I used to have a e46 325i, e46 330ci and now an e46 M3, stock is very well engineered, just replace it with OEM airfilter and call it a day. I used to have a 330ci and had BMW performance intake and it didn't do any notable difference, neither does Dinan. If you want some kick get a performance engine software it wont give much HP gain but will increase throttle performance.
[USMC]Skywalker is offline   Reply With Quote
Old 06-02-2014, 11:47 PM   #4
rplogue7
it's usually constructive hate in some sort of shape. so your saying a chip + intake would give me gains but without the chip I'm getting nothing but noise
2001 325ci vert
Old 06-02-2014, 11:50 PM   #5
unevolved
My Ride: 2003 325i
Potentially, yes. But a worthwhile "chip" (actually a retune, not a physical chip you replace) will greatly exceed your budget.
Old 06-03-2014, 01:19 AM   #6
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
I have to respectfully disagree.
I'm a firm believer that the CAI is worth some WHP, & should absolutely be considered in any N/A setup.
OP: The cheapest CAI I know of is from Cosmo Racing, they claim 7 / crank HP, realistically figure 4 to 6 WHP. Cost is about $165 shipped.
http://www.cosmoracing.com/productin...d=165&pid=1486
If you were to save up & buy a Shark Injector (from forum sponsor Turner Motorsports) at the same time,.....well you'd probably send me a case of my favorite beer; because it would feel that good. Promise.
Good luck,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 06-03-2014, 01:23 AM   #7
philliplong
My Ride: 2002 325CI
You could make your own like me! :cool:
philliplong is offline   Reply With Quote
Old 06-03-2014, 01:38 AM   #8
Rob43
Rob43's Avatar
Nice !
I would vent that cold air into it that's just sitting dormant from the center hood scoop.
Rob43
Old 06-03-2014, 02:05 AM   #9
philliplong
My Ride: 2002 325CI
Originally Posted by Rob43 View Post
Nice !
Rob43
I want to but I don't know exactly how I want to do it yet but I planned on getting to it at some point. I do have to agree with you. It is good for a few HP.
Old 06-03-2014, 04:27 AM   #10
HakenTT
My Ride: 323i with S54
Rob43
I have to factually disagree with you. Stock airbox is not restrictive at all for 2.5L engine, and it draws air from outside. 16 year old kids who just buy their E46 because they are so cheap now, think that BMW engineers are so stupid they did not watch fast and furious movies and don't know about short ram made in chine cone filter.
HakenTT is offline   Reply With Quote
Old 06-03-2014, 08:11 AM   #11
rplogue7
Good luck,
Rob43
alright so the total cost of this would be a little north of $500, not too bad. I have another question, would the intake be ineffective without the shark injector? In other words, should I Install a shark injector and an intake afterwards, so when I do have an intake the ECU will be set up for it?
2001 325ci vert
Old 06-03-2014, 08:33 AM   #12
Swater330i
My Ride: 2003 BMW 330i 5MT
The cheapest CAI won't give you 4-6 hp. There has been tests where it was concluded that a cheap intake can lose you 2 hp in our cars. The BMW performance box supposedly gives 6.5-8hp, and it's the only one I'd trust in our cars, unless you're going FI. If I was looking for cheap performance I'd get a software flash and do inspection II maintenance items + vanos seals.
Originally Posted by phenom323ci View Post
I am going to install M3 fender grill on my 323ci.
Originally Posted by futureSubie View Post
IMO, the euro clear corners looks too aftermarket/ricey.
Originally Posted by Davconelectric View Post
This 323 would most likely handle and drive better than a stock e46 m3.
Swater330i is offline   Reply With Quote
Old 06-03-2014, 08:51 AM   #13
erickonphoenix
My Ride: 2004 325i Touring
a cold air intake needs to be isolated from the heat of the engine. Most good kits supply a heat shield but they should be supplementally insulated as well. If your feeling extra motivated you can route fresh air to the intake with brake ducting. Also, some kids think these provide "off the line" improvement but they don't. If you get any bump from them at all it's at higher speeds.
erickonphoenix is offline   Reply With Quote
Old 06-03-2014, 08:53 AM   #14
Swater330i
Hey OP check out this video, , and more from these guys. They will save you a lot of money on your car.
Old 06-03-2014, 11:34 AM   #15
philliplong
My Ride: 2002 325CI
How did I know this was going to turn into a CAI war?
Old 06-03-2014, 11:56 AM   #16
unevolved
My Ride: 2003 325i
If you want an intake, buy an intake. It's not going to change your life. It'll make noise, maybe a tiny bit of power, and that's it.
Old 06-03-2014, 11:57 AM   #17
unevolved
My Ride: 2003 325i
At the end of the day, you still make less power than a minivan. It's not a muscle car.
Old 06-03-2014, 12:42 PM   #18
Tangent_
My Ride: '01 330i, '11 Z435i
BMW engineers aren't stupid. BMW engineers are also not allowed to design a street car with no restrictions on cost or noise levels. It's funny what kind of an intake they choose when they are allowed to dismiss those concerns though...
I'm not claiming the stock intake is so restrictive you gain huge numbers by replacing it, but claiming the intake we get from the factory is the best performance solution is naive at best...
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 06-03-2014, 12:42 PM   #19
Rob43
Rob43's Avatar
^ Yep.
You can do them separately & it doesn't matter which one is done first. If I were doing it, I'd buy the Shark* from Turner Motorsports first because of the excellent driveability. I made a little over 6 WHP with a before & after dyno, but it's the driveability with the Shark that really is the amazing part.
Oh, and back to the CAI argument: When I'm at the race track on any given SCCA race weekend, Nobody is running a stock airbox (except in a Miata because the Rule Book says you have too) in their race car. Everyone runs some form of CAI, if a stock airbox in a Bimmer or any other car were worth a grain of salt, racers would still be using the stock part,......but they're not.
Good luck,
Rob43
Old 06-03-2014, 12:44 PM   #20
Tangent_
Nice !
Rob43
The K&N does that.
