Thread Tools Search this Thread Rating: Thread Rating: 31 votes, 4.97 average. Display Modes
Old 07-11-2005, 09:39 PM   #121
edco
My Ride: 2004 325cic 2011 X5
You can do it !
Originally Posted by ideal_vx6
errrg... scared to mess with the windows. front passenger side makes a crazy cracking sound on the way down, and goes up really slow.
There is no miracle..It's broke and needs to be fixed.. there is enough history here so you should feel comfortable doing it..Tommie built a step-by-step instruction..and if I can do it, ANYONE can..
Be patient..go slow..disconnect the neg terminal FIRST for the airbag..slowing work the vapor barrier off..and the hard part is over..couple of bolts..a little twisting in and out of the old cable...and everything goes back together..just have someone to HELP you (wife or girlfriend will work)nudge the glass up or down so you can see the 8MM bolt line up with the hole in the frame..get some duct tape to hold the glass (along with the gf or wife or neighbor)in place while you loosen the bolts that holds the clips that hold the glass..the biggest danger is the glass getting away from you and falling into the door (and breaking)..
"You can do it !" - every Adam Sandler movie
edco is offline   Reply With Quote
Old 07-12-2005, 09:42 AM   #122
bmw2k
My Ride: 328i '00
Thanks for DIY writeup! I did my rear right door yesterday. It took it me jus a bit over 1 hr.
The one thing i'd like to add, I did not remove vaport barrier completely. The top seam stayed untouched. I started removal from the bottom, and as soon as regulator upper nut became visible stoped pealing it off. (Used scotch tape to get vapor barrier out of my way).
bmw2k is offline   Reply With Quote
Old 07-12-2005, 01:22 PM   #123
dokedoke
My Ride: 2001 Black 330ci
Send a message via AIM to dokedoke
anyone else know of a good place to find them? I cant find any for my 2001 330ci front right...? I need one asap!
dokedoke is offline   Reply With Quote
Old 07-12-2005, 03:11 PM   #124
dokedoke
so far the only place is pacific..with a price of 113 shipped. anyone else?
Old 07-12-2005, 04:13 PM   #125
bmw2k
My Ride: 328i '00
circlebmw.
I do not know how much is the front one, but for my 328i 2000, rear was $60 + shipping.
Old 07-12-2005, 06:07 PM   #126
edco
Try Google
Do a google search on BMW 330Ci Window Regulator..there's a bunch of them
Old 07-13-2005, 10:59 AM   #127
dokedoke
Google search= none for a 330ci bmw front regulator...i looked for over 2 hours of calling/searching.
Old 07-13-2005, 01:56 PM   #128
edco
Sorry...
Sorry..when I did it, I saw a bunch of names come up..although I didn't go any deeper than the google page so it's probably just a listing and they don't actually have it..
My apologies
Old 07-20-2005, 11:46 AM   #129
tommiexboi
My Ride: 328i > 335i > M3 cab
Send a message via AIM to tommiexboi
http://catalog.advancebmwparts.com/?...2001&x=38&y=12
thats for a 01 330ci
and then click body mechanical .... and window regulator
[SOLD] "The OG M Parallel Master" =) ------------------------- [New] 2008 E90 335i "White Monster"
New Pictures 5/22
Window Regulator Write-up (DIY)
tommiexboi is offline   Reply With Quote
Old 08-16-2005, 07:19 PM   #130
m1r
My Ride: 13 TL
good diy
m1r is offline   Reply With Quote
Old 08-18-2005, 07:12 PM   #131
lowviscosity
My Ride: '99 BMW M3 '13 VW CC
This takes about 30 minutes and saves over a hundred bucks. Nothing better than that. I did mine a few days ago real easy no reason not to try if your alright at putting things back together. So far I've done Spring Swap, Oil change, Window Regulator, Blinker change , Fog light change... all simple and all I used to do on my old honda was rotate tires and oil.
1999 BMW ///M3 Cabrio Dakar Yeller II.
lowviscosity is offline   Reply With Quote
Old 08-25-2005, 09:40 PM   #132
Saphire330XI
My Ride: 02 330XI & 07 Tundra
Tommie thank you for your help just finished the window regulator your DIY was very helpful.It took me about an 1 hour I have a 2002 330XI and I believe that they made a few changes nothing major but just minor. In may case I used a a 20mm hex and a 30mm hex along with a 8mm socket and a 10mm.
Saphire330XI is offline   Reply With Quote
Old 08-25-2005, 10:08 PM   #133
E46007
My Ride: 01 330ci hellrot red
my coupe is making a clicking sound and sounds like its hitting the window on the way up and down. could this be the regulator messing up? havent opened it yet. oh its a coupe.
E46007 is offline   Reply With Quote
Old 08-26-2005, 02:19 AM   #134
kap09
My Ride: 2014 S4 DSG
just stopping by to say thanks, as i used this to fix mine today
2014 S4 | DSG | Ibis White | Sport Diff | 19'' Peelers | MMI | Carbon Atlas | B&O | Side Assist | SC Badged
GIAC Stage 2 v2 | GIAC DSG | Roc-Euro Intake | Magnaflow Res'd X-Pipe | OE Sport | Alu Kruez | H&R Sways | ECS Flush Kit | 40% Pinnacle Tint | Hoen Endurance | VCDS Mods | Escort 8500 x50
Past Rides
2013 S4 6MT//2010 A4 Quattro//2000 BMW 323i//1991 Integra//1990 Jetta//1993 Civic
kap09 is offline   Reply With Quote
Old 08-26-2005, 02:45 AM   #135
goowatchi
My Ride: tiag step 330ci
Send a message via AIM to goowatchi
Nice write-up, hope I don't need to use it, *knock on fake wood trim*, but I subscribed just in case Thanks!
goowatchi is offline   Reply With Quote
Old 08-31-2005, 12:22 AM   #136
atomicgroove
My Ride: 2 BMW E46 Jeep TJ
GREAT INFO!
I changed my driverside window regulator tonight.. it was easy thanks again for the great info..
this is what the new one looks like.
compare old to new
The old one....
The new one...
atomicgroove is offline   Reply With Quote
Old 08-31-2005, 04:12 AM   #137
Drunken_Ninja
My Ride: 318i
How do attach the wire pullys to the motor? Mine wer busted before and I am not sure how to reconeect them to the motor...
Cheers
Drunken_Ninja is offline   Reply With Quote
Old 09-05-2005, 05:40 PM   #138
tommiexboi
if the wires are busted, you cannot just connect back together again, you need to purchase another window regulator.
hey guys! thanks for all the compliments... if you guys have any urgent problems just PM me or IM me on AIM: Tommiexboi .... good luck to you all =)
New Pictures 5/22
Old 10-16-2005, 05:13 PM   #139
mperfct
dot eleven N for the win
mperfct's Avatar
My Ride: 97 M3
Send a message via AIM to mperfct Send a message via MSN to mperfct Send a message via Yahoo to mperfct
My front passenger side just went out this weekend. I was able to get the window up and hopefully will get to change the regulator on Wednesday. I have to deal with an airbag as well, but hopefully there won't be many differences other than just disconnecting the negative terminal on my battery. I'll post it up if there are many complications due to the airbag.
Chris
My home theatre thread
Audi A6 4.2
mperfct is offline   Reply With Quote
Old 10-16-2005, 06:07 PM   #140
Surk
My Ride: C Blk E46///M3
Excellent long overdue DIY... Haven't had to do a wind reg yet.. but this will help when I do...
Surk is offline   Reply With Quote
