///M3 Forum
Old 06-08-2014, 02:36 PM   #1
Cayne23
My Ride: 2002 m3 convertible
Results of vanos test
https://db.tt/nBWuNosO
Actually an incomplete test. Well my timing should be good. Have not messed with it. Vanos hydraulic unit should be the solenoid pack not actuating the valves properly. That unit has been cleaned and o rings replaced via besian.
My problem has to be the solenoid.
Its nice being able to do a vanos trst whenever I want. Great software
Cayne23 is offline   Reply With Quote
Old 06-08-2014, 10:23 PM   #2
Cayne23
Oops, wrong pic. https://db.tt/f8ZJTmWF
Old 06-09-2014, 12:18 AM   #3
taylor192
My Ride: 2003.5 M3
So it's exactly what we told you a hundred times in one if your other hundred threads. How about you update one of those threads rather than keep posting new threads.
Old 06-09-2014, 05:14 AM   #4
Cayne23
Lol^ sorry. Its been forever since those posts. I just wanted to zero in on the problem. Yes I am ordering the solenoid pack
Old 06-30-2014, 07:12 AM   #5
Cayne23
UPDATE:
Changed my solenoid pack,......no change
Old 06-30-2014, 08:09 AM   #6
choxor
My Ride: JDM
You have so many threads on this I don't even remember what's going on.
Anyway, if it's still throwing VANOS codes then you need to check your hub tabs. You might as well check the timing, too.
Old 06-30-2014, 02:47 PM   #7
Cayne23
Yea........ugh
Old 06-30-2014, 02:50 PM   #8
Cayne23
Code B8- vanos inlet. Or generic coee p0012- intake timing over retarded
Rough idle, low power, foul exhaust smell
Old 06-30-2014, 02:58 PM   #9
Cayne23
Oh, and I didnt think the timing would be off because I havent disturbed it. I read somewhere that timing can only be off if mechanically disturbed
Old 07-02-2014, 10:29 AM   #10
Cayne23
Also noticed that when I took everything apart, the valves in the block were not clicking when I put a magnet on them. I had just cleaned everything 1000 miles ago. So I cleaned them again. Weird they were that dirty already
