Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Suspension and Braking
Springs, shocks, struts, coilovers, camber plates, sway bars, strut bars, suspension bushings, control arms, brake pads, big brake kits, etc.
Old 06-25-2014, 07:32 AM   #21
Jalaly25
My Ride: BMW 325Ci
Craigslist post is deleted by Author. Any info & pics of the coilovers? Fits 05 325ci?
Jalaly25 is offline   Reply With Quote
Old 06-25-2014, 08:03 AM   #22
GGray
My Ride: 01 325it Wagonator
I will get the link back live tonight when I get home.
I forgot I pulled the add.
Gary
Need parts, or a race shop?
email us - [email]info@simod.net[/emaill
Follow us on facebook
If you can take it apart you can make it faster
GGray is offline   Reply With Quote
Old 06-25-2014, 11:44 AM   #23
SOMT
My Ride: 2000 328Ci
Good deal, would have already purchased if I had the funds.
SOMT is offline   Reply With Quote
Old 06-25-2014, 12:08 PM   #24
Jalaly25
My Ride: BMW 325Ci
If it's the correct coils then I'm in.
Old 06-25-2014, 12:13 PM   #25
Jalaly25
My Ride: BMW 325Ci
Old 06-25-2014, 03:51 PM   #26
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
If it's the correct coils then he's in
SUMMIT POINT WV 1:24:229 SCCA
Old 06-25-2014, 04:43 PM   #27
Jalaly25
My Ride: BMW 325Ci
Double post from lack of service at work. Love you tho Rob
Old 06-25-2014, 05:12 PM   #28
sunnyjay
My Ride: 01 330i
I believe it might have been sold since the OP deleted his craigslist ad.
sunnyjay is offline   Reply With Quote
Old 06-25-2014, 09:34 PM   #29
GGray
pic.. for some reason this is the only one my editor program would let me resize
Koni SA 40k converted to coil over about 10k ago.. you can look at the springs and tell they look almost new..
K sport camber/caster plates work great a PITA to adjust they are adjusted bolt on!
rear spherical shock mounts rubber isolated, cut down bump stops siliconed to washer to keep from moving up and down shock rod
coil over drop on sleeves up front
height adjusters in rear with the bolt and washer to secure to arm, and like new nylon spring locators.
Eibach springs, front: 2.5inch 6inch 450 pounds. Rear: 2.25inch, 5inch, 600 pounds
Two Koni adjusting knobs for front. rear are adjustable push up to adjust version adjusted to 3/4 stiff where they need to be left.
Of course the Koni crappy paint was flaking off and had surface rust so I sanded them down primed sanded and painted as close a yellow as home depot had to Koni yellow.. Possibly overkill but I suffer from OCD....
Gary
Old 06-26-2014, 08:27 AM   #30
GGray
Exclamation
Ok.. STILL for sale... No payment received yet...
Gary
Old 06-26-2014, 08:34 AM   #31
GGray
Yes bolts right on!
Gary
Old 06-27-2014, 10:12 AM   #32
GGray
daily bump!
Gary
Old 06-29-2014, 08:11 AM   #33
Rob43
Rob43's Avatar
I can't believe these haven't sold yet.
Old 07-01-2014, 08:36 AM   #34
GGray
You would think, the springs and hardware are worth more than what i am asking for the entire set up...
daily bump..
Gary
Old 07-01-2014, 08:43 AM   #35
SOMT
My Ride: 2000 328Ci
I wouldn't go THAT far.... But I think we know what you mean. The struts and shocks have 40k on them?
Old 07-01-2014, 08:52 AM   #36
GGray
yeah of driving up and down the interstate back and forth to work and two weekends at track... typically Koni's last well over 100k.
Based on a set of crappy Racelands that cost more and last maybe 20k.. I'd say its a deal for someone...
Gary
Old 07-01-2014, 08:59 AM   #37
SOMT
My Ride: 2000 328Ci
Definitely not saying it isn't a deal. I'm sure someone will pick these up
Old 07-02-2014, 07:03 PM   #38
AdaRi
My Ride: 2004 325i e46 sedan
Sorry if I missed this but how much is the drop on them? This is a fantastic deal and I am definitely interested.
Work in Progress.
2004 325i Sedan GrauGruen Metallic
Beyern 19x9.5 front, 19x10.5 rear/ Clear LED side markers/ Black Roundels/ Matte black kidney grilles/ Smoked m3 tails/ Clear Corners/ Front LED turn signals
Intake manifold/ Coolant Hard Line DIY
AdaRi is offline   Reply With Quote
Old 07-02-2014, 07:50 PM   #39
Eurrofreak
My Ride: 323iT, E36 325i
pm sent
Eurrofreak is offline   Reply With Quote
Old 07-02-2014, 11:09 PM   #40
AdaRi
Didn't receive a PM. Not sure if that was intended for me or someone else.
Work in Progress.
