Old 06-19-2014, 12:24 AM   #1
kdoubt
My Ride: 330i
"Double" intake 330i?
Well, I've been shopping around for intakes and noticed a lack of dual filter options. I got to thinking why-not or why this may be and figured a double option must conflict with the most effective way to draw air or poses a maintenance challenge.
Does anyone know why I'm unable to find anything?
Is there a mathematical reason there isnt something like this inside the airbox?
Anyway, I'm really just thinking out loud on the internet. I think it looks pretty cool and figure theres more surface area on the filters (could be way off on that). Chime in if you have a degree in aerodynamic engineering
kdoubt is offline   Reply With Quote
Old 06-19-2014, 02:33 AM   #2
reggid
My Ride: .
for a given width (space envelope) the cross sectional surface area of the two filter setup inlet tubes is half as much despite surface area of filter element being the same....
also i big filter is cheaper than two little ones most likely
reggid is offline   Reply With Quote
Old 06-19-2014, 03:18 PM   #3
Tangent_
My Ride: '01 330i, '11 Z435i
The one filter used on common CAI for our cars flows more than enough. Even if a dual filter setup was made that had more capacity it would be wasted. More expense, more complicated fitting getting them in the same area as a single one, more to clean, etc...
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 08-13-2014, 11:26 AM   #4
Bino5150
My Ride: 99 323i
Correct me if I'm wrong, but that pic looks like it fits on a carb. If that is the case, then that is why it's a dual filter; the single cone doesn't offer enough surface area for the flow needed for a larger engine.
Keep in mind, on the M54, all the air taken in will be routed back into a single pipe, through the MAF, and into the tb. Without dual tb's, there is really no need for dual filters.
Bino5150 is offline   Reply With Quote
air, airbox, double, dual, filter
