///M3 Forum
Old 06-19-2014, 04:27 PM   #1
iansevilla
My Ride: 2004 M3 Coupe
Engine backfire?
Has anybody here experienced a backfire at high rpm when shifting from 1st to 2nd? It happens right after you let go of the pedal and shifting to 2nd?
iansevilla is offline   Reply With Quote
Old 06-19-2014, 04:30 PM   #2
iansevilla
This happened a few days ago. Installed new plugs and backfire went aways. Then, it came back today?hmm...
Old 06-19-2014, 09:32 PM   #3
iansevilla
Any ideas what causes it?
Old 07-02-2014, 02:59 AM   #4
iansevilla
Bump
Old 07-02-2014, 08:54 AM   #5
Redline
Redline's Avatar
My Ride: ///M3 Vert
Talking about a pop from the exhaust when you shift? It's normal when near redline. DSC can cause it too.
k.
///M
Old 07-02-2014, 12:14 PM   #6
api
My Ride: 03 M3 6-spd
The backfire sound is when the excess fuel is not ignited in the cylinder and falls into the exhaust and ignites in the exhaust. The less restrictive your exhaust is the more noticeable and louder it can become.
MODS: 03 M3, 6MT, PSS9, AFE Intake, Euro Ceramic Coated Headers, El Diablo Exhaust, Turner Motorsports Rear Adjustable Camber Arms, AKG Diff and Subframe bushings, PowerFlex suspension bushings, Sub-frame Reinforcement, 18'x9' square setup & one driver that grins ear to ear everytime he is driving it
api is offline   Reply With Quote
Old 07-02-2014, 12:17 PM   #7
BartenderPlease
My Ride: '03 540i/6 M-Sport
A backfire is the explosion made in the compression stroke coming out of a leaking intake valve(s) or a stuck open intake valve(s). Are you sure this is a backfire, it doesn't sound like one. Maybe a misfire?
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Fiber Trim |
BartenderPlease is offline   Reply With Quote
Old 07-02-2014, 12:44 PM   #8
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Why would dsc have any effect on a backfire
Old 07-02-2014, 12:51 PM   #9
MitchM
My Ride: a slow piece of sh1t
Sounds good, leave it
1412429_10201452546428622_989678193_o
MitchM is offline   Reply With Quote
Old 07-07-2014, 10:37 AM   #10
Redline
Redline's Avatar
My Ride: ///M3 Vert
It gives the effect of a backfire, dsc cuts power if you're wide open right when you drop the clutch after a high rpm shift to prevent wheel chirp/back end breaking loose. Then it instantly starts dumping fuel after that small pause, it's give a very loud pop out of the back end of the car which most will think was a backfire.
k.
///M
Old 07-07-2014, 06:44 PM   #11
peytonracer4
:D
My Ride: '00 328i
That would be a backfire. Just out the exhaust. Not the intake. And my dsc has never done this.
Old 07-08-2014, 12:17 PM   #12
MachRc
E46Fanatic
MachRc's Avatar
My Ride: 2003 Technik S1 M3
I get it once in a blue moon( my tune is on the rich side) when i shift at a near the redline under load, but it's not all the time. It does makes my 1-2 or 3rd to 4th feel like the most perfect direct shift with a slight ting-y sound.. I do not get a loud bang or a shotgun sound, but a slight metallic pop from the rear.
I wouldnt expect this from a stock e46 m3 with stock cats but anything is possible with so many variables.
edit: the only time I had lots of backfiring was due to a ban bremi coil. But it sounded like a diesel, and it would throw codes
"Player-haters turning bitch like they have vaginas ‘Cause we see them dollar signs and let the cash blind us.
Money'll brainwash you and leave your ass mindless..When snakes slither in the grass spineless.."
MachRc is offline   Reply With Quote
Old 07-08-2014, 05:27 PM   #13
peytonracer4
:D
My Ride: '00 328i
I wish my car would throw flames at redline. That would be sweet
Old 09-01-2014, 02:22 AM   #14
iansevilla
Found the problem with my engine backfire at high rpm. Air filter was clogged... Found out when I replaced it with AFE stage 1. No more back fire at high RPM..
