E46 Convertible
Old 06-20-2014, 08:45 AM   #1
azbimmer
My Ride: 06 330 cic
Help with Installing a replacement H7 battery
I have a 2006 330 CI convertible since new with only 45K miles. I replaced the second OEM battery with a Sam's Club Energizer MAX H7. It appears to be slightly longer than the Exide OEM, so the small metal piece holding it in place does not fit.
Any suggestions on how I can secure it? Thanks for all the inputs. I love this car.
azbimmer is offline   Reply With Quote
Old 06-21-2014, 07:51 PM   #2
azbimmer
My Ride: 06 330 cic
Anyone?
Old 06-22-2014, 03:35 AM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Here is my suggestion, buy an OE battery from the dealer. Hopefully they have online pricing so you can get it for less than $300.
You may say I am nuts, the battery is special in the convertible. Do not laugh, the battery is an integral part of the overall vehicle vibration dampening system. Just check the owners manual and service manual.
You will notice the battery is mounted on a tray that is gimbal mounted with 2 small shock absorbers, BMW did not do this for no reason.
Also since your car is likely not driving for long periods as seen by the mileage, suggest you buy a Battery Tender and use it when the car is sitting for more than a few days.
Old 06-22-2014, 04:54 PM   #4
Adamo99
My Ride: 2016 Wrangler 75thAE
It's a friggin' battery. I bought a replacement at Walmart for $96, and it was rated better than the OEM in every way. The handling, NVH, and suspension didn't all go to **** when I replaced it. Just buy one that is the same size, lock it down, and you're all set.
Adamo99 is offline   Reply With Quote
Old 06-23-2014, 04:03 AM   #5
jfoj
Hey, all I am saying it there is something about how the convertible is built and the battery plays into it. Right, wrong or indifferent, I am just passing the info along. Many folks may not be aware of how the battery is actually a design aspect of this car.
I cannot say what may happen if you do not use the OE size/weight/design battery, but BMW did something very weird with the E46 and the battery. May be not something your average Joe would noticed, maybe if you luck out and get a battery that is very close, it will still work?
This one item I may not cheap out on just because, but to each their own.
Old 06-23-2014, 10:52 AM   #6
dagny747
My Ride: 330cic ZHP
I think the operative question was how to secure it as the H7 doesn't line up with the metal clamp. Unlike the hardtop which has a top clamp there is not one on a convertible. Where i live the dealer price is the same as walmart/autozone. So it's a no brainer, buy the BMW battery. I understand that in other parts of the country, the dealers charge up to $300 for a battery. My 2005 original lasted until 2013 and cost $156.
dagny747 is offline   Reply With Quote
Old 06-23-2014, 11:29 AM   #7
wildirish317
My Ride: 2004 325Ci vert
Per Bentley:
The only downside is battery life.
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
Originally Posted by Mike Miller
I just don't know what I'd do with 560 hp that doesn't involve getting arrested.
wildirish317 is offline   Reply With Quote
Old 06-23-2014, 10:25 PM   #8
azbimmer
My Ride: 06 330 cic
Thanks for bringing the discussion back to topic. I have already installed the battery. It is just not secured, because the clamp would not fit since it is a tad too large. If I had access to a machine shop, I could trim it down!
As we all know, BMW does not make batteries (or tires!). They use an Excide battery, and I doubt very much if Excide does something to make their battery more anti-vibration, especially since it is the same battery for the convertible and the sedan. The aftermarket is made by Johnson Controls, a reputable maker, with better specs than Excide, and is $100 cheaper than the dealer's price.
My only question is, has someone else installed an aftermarket battery in the convertible, and if yes, how did you secure it?
Any takers?
Cheers!
Old 06-23-2014, 10:26 PM   #9
azbimmer
My Ride: 06 330 cic
Originally Posted by wildirish317 View Post
Per Bentley:
I have a Bentley manual. Where is this quote?
Old 06-24-2014, 05:52 AM   #10
wildirish317
It's under convertible top controls, page 541-1. The special battery tray and constant vibration are mention in several locations. This is the only one I found that says it will shorten battery life to use a battery not designed for constant vibration.
Old 06-24-2014, 08:33 AM   #11
azbimmer
My Ride: 06 330 cic
Thanks for sharing. My first 2 OEM (Excide batteries) lasted 3 and 5 years respectively. We will see how much this one lasts, but the cost saving of $100 ($140 vs. $240 from dealer) will offset that.
Old 06-24-2014, 11:07 AM   #12
wildirish317
You're welcome. My battery turned 5 years old this past December. I don't recall if it's OEM (or designed for constant vibration). I'm expecting it to die any time, although it shows no signs of being weak. fwiw, I have the same warning about the battery on my Sawzall.
Old 06-24-2014, 03:14 PM   #13
SilberVogel
My Ride: 2002 330Ci Conv.
Any takers?
Cheers!
The Duralast Gold (94R-DLG) from AutoZone is a perfect fit, so when I replaced mine, there were no issues with securing it. Was aware of the design aspects of the convertible battery at the time I was replacing the OEM one, and have been running the 94R-DLG for about four years now without any issues. Didn't weigh the OEM and Duralast batteries, but their dimensions/appearances were identical, right down to the vented port.
EDIT: The Duralast also came with an 8 year warranty (3 year free replacement), so figured I couldn't go wrong.
DIYs help you save money with repairs; let www.bmwpnpc.com help you save money with the parts.
SilberVogel is offline   Reply With Quote
Old 06-25-2014, 09:40 PM   #14
Adamo99
Per Bentley:
Buying the proper size battery (94R) allows it to be securely mounted in the tray. That eliminates any vibration, and excess stress on the battery. Mine has been fine for years- but if it helps you sleep better at night paying triple for everything 'because BMW says so', knock yourself out.
Old 06-26-2014, 09:26 AM   #15
azbimmer
My Ride: 06 330 cic
I did buy the proper size (H7 is same as 94R), but it is just a tad longer, maybe 0.1 inch, so the bracket used to secure the battery does not fit. The H7 replacement has better specs than the OEM Excide that BMW wanted to sell me for $100 more!
http://www.samsclub.com/sams/energiz...prod6000038.ip
Old 06-26-2014, 06:21 PM   #16
Adamo99
It's not the same then, is it? Buy the correct battery, no problems. BMW doesn't make batteries- they just source and install one that meets their engineering specs.
Old 06-26-2014, 07:26 PM   #17
wildirish317
You're replying to the guy that fixed his DISA with epoxy. I won't spend 3x for a BMW label on my battery.
Sent from BimmerApp
Old 06-26-2014, 08:38 PM   #18
azbimmer
My Ride: 06 330 cic
Problem solved
I took the metal piece that holds the battery down to the local Ace Hardware, asking a helpful fellow if I could find an alternate, smaller piece.
He said, If you want, I can cut it short.
"Sure," I said, and watched him use a hacksaw to cut the piece.
It fits perfectly.
Thank you, Ace Hardware, for saving me $100!
Old 07-04-2014, 09:39 PM   #19
jimvideopro
My Ride: 2006 330CiC
For those searching in the future: the H7 Everstart battery from Walmart I just bought fits perfectly. $146 plus tax. Note that there are vents on both sides of the battery, but the cover over the positive terminal had a little break-away plug I used to close off the vent on the negative side. Sometimes it DOES help to read the directions!
jimvideopro is offline   Reply With Quote
Old 07-05-2014, 05:51 AM   #20
salmab
BMW 650i 2007 car crank but won't start
salmab is offline   Reply With Quote
battery replacement, h7
