Old 06-21-2014, 11:19 AM   #1
Sc04cbra
My Ride: 01 325i Sedan
A/C compressor doesn't work
My old a/c compressor didn't work, clutch wouldn't engage and air wouldn't blow out of the vents, so I replaced the a/c compressor yesterday.
Air now blows out of my vents, however the clutch doesn't engage.
I have no idea where to begin diagnosing the issue.
Any help is greatly appreciated.
Sc04cbra is offline   Reply With Quote
Old 06-21-2014, 09:00 PM   #2
Sc04cbra
Found the solution, the fuse for slot #37 was missing. Replaced it and now the clutch works perfectly fine
Old 08-23-2014, 02:51 PM   #3
nickchen
Send a message via ICQ to nickchen
Hi I have the same problem I have changed the compressor but it does not kick in no idea where the relay is located I have checked under the glove box and checked the fuses for the air con they all seem fine according to the chart provided for all the fuses . Please advise
nickchen is offline   Reply With Quote
