Sponsored by The Tire Rack
Old 06-21-2014, 10:22 AM   #1
FaisalFazeli
My Ride: BMW E46 SALOON/SEDAN
Send a message via ICQ to FaisalFazeli
Spacers help
Hi guys,
I have ordered lowering springs 40/40mm for my e46 saloon and my offset for my rear wheels are really high its 245/40/18 and it has been arched already and doesnt rub yet, now after i put these lowering springs, i would want to get 15mm spacers for front and rear 10mm spacers..
Would all this adding to these wheels make it rub the arches or not?
HELP PLEASE
FaisalFazeli is offline   Reply With Quote
Old 06-24-2014, 12:05 AM   #2
Evo Panda
My Ride: E46 328i, MK6 GTi
If you are lowering it 40mm from the stock non-sport ride height I don't think you will rub with 245/40/18's. If you do, you'll just have to roll the arches
Evo Panda is offline   Reply With Quote
Old 06-25-2014, 04:25 AM   #3
FaisalFazeli
the arches have already been rolled so should be fine right? would you suggest spacers then or not?
Old 06-25-2014, 07:23 AM   #4
tachi1247
My Ride: '04 330i
What are the offsets of your wheels? Can't really determine what spacers will fit without knowing the offset.
If they are genuine bmw wheels, post a picture and we can look up the specs.
tachi1247 is offline   Reply With Quote
Old 06-25-2014, 07:24 AM   #5
FaisalFazeli
Sorry dont know the offset of the wheels but this is a picture and they arent the genuine bmw wheels
Old 06-25-2014, 08:34 AM   #6
tachi1247
My Ride: '04 330i
Looks like the tires are already stretched so that works in your favor if you want spacers. Your going to have to take a wheel off and get the offset though if you want to know for sure. It will be stamped on the back somewhere, should say etxx where xx is a number.
From this photo it looks like your wheel sticks out post your fender already so I'm not sure how much wider you really want to go...
Also be careful with 10mm spacers. You need to measure the lip on the hub as it might also be 10mm which can lead to the spacer not seating flush against the hub which is a huge problem. You may have to go 12 mm to make it work out go less and get a hub extension like Turner sells.
Old 06-25-2014, 08:35 AM   #7
tachi1247
My Ride: '04 330i
I would also lower the car first and then determine of you want the spacers. They are super easy to install so it's not a big deal to do them afterwards
Old 06-25-2014, 08:40 AM   #8
FaisalFazeli
Thanks mate!
Ok so tomorrow ive booked a garage to put my lowering springs on, would you suggest to put front only? Because the rear is sitting nice but i wouldnt mind it lower just dont want it to rub arches? Ive got front and rear 40mm lowering springs? Garage quoted me 120 with wheel allignment so not bad
After that would know if id need spacers or not just praying it doesnt rub with these tyres Click image for larger version
As you can see the fronts really high thats my main purpose of lowering the car but came in a set of rear too
Old 06-25-2014, 08:57 PM   #9
tachi1247
My Ride: '04 330i
I would probably put them all on. Equal (or at least matched) spring rates at all four corners would probably ride and handle better
Old 06-26-2014, 04:01 PM   #10
FaisalFazeli
Front wheels are done and dont see much difference letting it settle in..
Changed the drop links too
Tomorow gonna finish off the rear.. Have a bad feeling rears gonna rub
Yes, i know i need to give them a good polish !
Old 06-27-2014, 04:50 AM   #11
FaisalFazeli
I have read behind the wheel and it says 8.5?
Old 06-30-2014, 07:21 AM   #12
FaisalFazeli
Yeah after lowering it, its sitting quite low at the back and wondering if i should get a camber kit?
As its rubbing only the corner of the tyre
Old 06-30-2014, 10:23 PM   #13
kingbimmerE46
Are your fenders rolled
kingbimmerE46 is offline   Reply With Quote
Old 07-01-2014, 04:42 AM   #14
FaisalFazeli
yeah its been arched
Old 07-02-2014, 03:12 PM   #15
DonaldE
My Ride: 2002 330i
Your wheel is fully tucked with 40mm drop?
I'll trade you rear coils.
I have Vogtlands that are slightly higher than yours.
I'm looking to go a bit lower in the rear.
Jet Black 2002 BMW 330i
Swapped M3 Interior
OEM Style 71s
Dropped on Koni/Vogtland
Locked/Loaded/Loud
DonaldE
DonaldE is offline   Reply With Quote
Old 07-02-2014, 03:51 PM   #16
FaisalFazeli
I like how its sitting? I'd only trade them for coilovers.
And im from UK.
