HELP!! Weird feeling coming from the rear - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 06-22-2014, 09:47 AM   #1
Sammysaba
My Ride: 2006 E46 M3- Sold
Hello all, for the passed few days my e46 M has been acting up and i have no clue why. Every time I go to get my car to a decent city speed limit at around 15-25 MPH I get this loud banging and rubbing noise from the back (i think right back) area of my car. If i didn't know any better (which i like to think i do) i would think it was a flat tire BUT it isn't. It feels like the car is jumping alittle and rubbing on something but once i pass that speed range and get to 30 or even highway speed the sound and feeling go away.
Currently I am running Staggered CSL Rep 19" with 225/40-19 in the front and 285/35-19 in the rear and i have been running this set up for well over a year now without a problem. I know my car needs a 4 wheel alignment and have already checked the tread on all 4 of my tires and they do need to be replaced soon ( maybe 2k more for them). I checked both my rear bearings and they are both fine. Yesterday I had all 4 of my rims checked for bends and obviously (living in Brooklyn) all 4 of them were slightly off and i had them all straightened. I even tried tires of a friend of mine to confirm it wasn't the wheels.
I am desperate at this point and have no idea where to look next...... could it be my axel? Or maybe my diff? I wish i could post a video and show what it is doing but that just wont help because the video does not show it.
If anybody has a solution or lives in the Brooklyn area that i can go show this too PLEASE let me know!!!
2002 E46 325Cic- For sale!
2006 M3 Convertible Jet Black on Dove Grey Scorpion exhaust Macht Shcnell Intake- Sold
2013 F10 M5!!!
Sammysaba is offline   Reply With Quote
Old 06-22-2014, 10:18 AM   #2
FTLAUDM3
My Ride: M3, Z4
1 rear diff fluid (OEM only)
2 get new RSM
3 Rear Rtabs
This are three items in the back that could cause issues.
FTLAUDM3 is offline   Reply With Quote
Old 06-22-2014, 10:52 AM   #3
Sammysaba
2 get new RSM
3 Rear Rtabs
I will definetly check these 3 do you know if this is something a BMW dealer would carry? Or am I better off finding them online?
2013 F10 M5!!!
Old 06-22-2014, 02:52 PM   #4
Teslazerok
My Ride: 2003 M3 6SPD
Lift/jack the car up and then drive it in the air at that 15-25mph area with someone under the car to see if they can identify where the noise is coming from.
My guess would be an issue with the diff/axles. Maybe a cv joint.
Blown rear shock mounts would make god awful noise hitting bumps, not at a certain speed.
Rtab's would badly affect your handling but you didn't mention anything about it so I assume it still handles fine.
Originally Posted by svtmike
Your TL is an eminently replaceable mass production inaninimate object that doesn't give a sh*t about you.
Teslazerok is offline   Reply With Quote
Old 06-22-2014, 05:10 PM   #5
Alex323Ci
My Ride: M3 & 323Ci (sold)
really hard to say without hearing it but....
kinda sounds like the limited slip differential
Old 06-25-2014, 08:00 AM   #6
Sammysaba
So I checked my Rsm they both needed to be replaced and in addition to that my shocks are completely dead. Being that this is my first BMW I didn't know they get stiff instead of extra uncontrolled bouncy. I just ordered the koni yellows for the whole car and I am hoping that this fixes the problem!
2013 F10 M5!!!
Old 06-25-2014, 01:32 PM   #7
Sammysaba
I took a video i dont know if you can tell from the video what is going on but i guess its worth the try
2013 F10 M5!!!
Old 06-25-2014, 01:41 PM   #8
Alex323Ci
you said you checked your rear shocks before and they were fine.
rsm's won't cause a repeated speed sensitive issue. it won't change what they do for your car at higher speeds.
you say now the shocks are bad and stiff? RSMs are easy to see blown, but may i ask how you checked and concluded the rear shocks are now bad?
glad you found the RSMs being broken, you may consider some heavier duty mounts since you have a convertible and the Koni yellows to now mate to.
Old 06-25-2014, 01:52 PM   #9
Sammysaba
I was under the impression that my shocks were ok because my father told me they were fine. Yesterday I was going my shock mounts and I took the shocks off the car. They are dead they do not extend properly. When pushed together the do not open back out they stick in.
Do you not think it's my shocks?
2013 F10 M5!!!
Old 06-25-2014, 06:27 PM   #10
Teslazerok
Well if you can fully compress them by hand and they don't rebound then they are 100% toast.
I still wouldn't think they were causing the original issue you described though.
When my RSM's went out I was worried a had a torn subframe from the the loud banging and clunking sounds I got whenever I hit a bump. Speed shouldn't affect it in any way and there shouldn't be a rubbing sound.
Old 06-25-2014, 06:38 PM   #11
Sammysaba
As of now I'm going to change my shocks and hope for the best if that doesn't help I will change my rtab and if not that I am going to have my diff checked out
2013 F10 M5!!!
Old 06-25-2014, 07:58 PM   #12
Competition05
My Ride: 2005 m3 ZCP
"Help! Weird feeling from the rear."
Are you being raped?
Competition05 is offline   Reply With Quote
Old 06-25-2014, 07:59 PM   #13
Competition05
Ps. Check your trailing arm bushings and sub frame bushing
Old 06-25-2014, 08:59 PM   #14
SKR7
My Ride: E46 MY04.5 SMG M3
I was going to suggest sub-frame bushings also....
///M
2004 E46 M3
SKR7 is offline   Reply With Quote
Old 06-26-2014, 09:09 AM   #15
choxor
My Ride: JDM
It sounds like you're on the original suspension. If that's so then your RTABs are shot. Go ahead and replace them. The part was updated and they have a real impact on how your car feels.
Old 06-26-2014, 10:22 AM   #16
Sammysaba
Did you check out the video I posted?? Is that sound I'd get from bad rtab?
2013 F10 M5!!!
Old 06-26-2014, 11:18 AM   #17
choxor
My Ride: JDM
Sorry man, I'm not good at diagnosing sounds from videos. I only mention it because the RTAB is a very, very common wear item so you might as well go ahead and add it to the list of things to change out if they haven't been changed before. I don't think they'd make a sound unless they were completely hosed and moving around in the carrier. Mine didn't. Mine even looked fine, but changing them made a world of difference.
Old 06-26-2014, 11:59 AM   #18
Sammysaba
It's all good I appreciate your help anyway. Did you do the rtab work yourself? That's the next step I'm taking if it isn't the shocks
2013 F10 M5!!!
Old 06-26-2014, 12:58 PM   #19
choxor
My Ride: JDM
Yup. Not hard. Just be sure to get the rtab tool. It's possible without it, but it's not worth it. An alignment is mandatory after doing the RTAB's, though, so take that into consideration.
Old 06-26-2014, 04:36 PM   #20
Alex323Ci
well i can't tell from your video but if it's making the noise as it "squats" from the torque and acceleration then it could be the RSMs. if they allow it to squat so much and hit tires or other compaonents it could certainly be the case. more likely RSMs banging in the convertible storage tray area. so in reality it's not a "speed" thing but a shifting of weight thing from power from shifting up. and then lack of shifting of weight at highway speeds. but if you hit bumps at highway speeds it should be making noises and feel loose then too.
again if the RSMs and shocks are shot replace those as it could certainly be the fix needed. if not, you needed to replace anyway and one more thing taken out of the possible issues.
