///M3 Forum
Old 06-25-2014, 03:43 AM   #1
0-60motorsports
My Ride: E30 325ic & E46 M3
Send a message via MSN to 0-60motorsports Send a message via Yahoo to 0-60motorsports
DIY: OEM CSL MAP/IAT/FLAP Wiring
Well here is my DIY attempt at converting my wiring to OEM CSL after replacing my MSS54 with a Terra Modified MSS54HP. I have an OEM CSL Airbox with Flap and all OEM ducting etc..
Starting to untangle the mess LOL.....
2 Prong cnnector for Flap Motor...
The flap motor pins are blank in the DME connector....
The three prong connector is for the Flap potentiometer or position sensor....
The naked flap snorkal intake thingy.....Getting ready to re-install the flap and motor....
Make sure you use the wire positions on the connectors to tap/solder to the correct wires in the DME...
Bye Bye MAF connector....
Map sensor Connector. Wires numbered 1-3 left to right....
Map Connector Wire 1 goes to red green wire in the connector box (box which has a lot of ground wires in it next to the strut tower)....
Map connector Wire 2 goes to brown Orange wire from MAF Plug (seen here top right)....
Map Connector Wire 3 goes to empty slot in DME connector Slot #18 which is empty....
Borrowed Map Rail from my friends CSL while it undergoes a full engine rebuild....
Wiring Diagrams I used to do the wiring...
Another version of the wiring guide thanks to member mwstewart:
I will add descriptions to the wiring pics above showing what and where its going etc.... LOL. Sorry Guys it was very very hot and it was very difficult taking pics and doing the work at the same time.
Most of you are going to be focusing on the MAP wiring and i'll go and take proper pics of that for you gents today.
EURO 04 M3: GC Coils, Eibach Sways, PF RTABs, RE RCAs, INTRAVEE II, Black Roundels, ///MFEST Badges, Depo's, VCSL Bumper + Race Lip + CF Trunk + CF Rear Diffusor + CSL center console, DIETZ TV in Motion, SS Stepped Headers, SS Catless S & Res X-pipe, SS Race, Z8 Starter Button, Lamin-X, OEM CSL Steering + CSL interior, OEM CSL Intake, EVOLVE Alpha-N Tune, BBS CH's, FX-R 3.0's, ST40's, DINAN Rear Strut Brace, BW Oil Cooler, 3.91 gears
0-60motorsports is offline   Reply With Quote
Old 06-26-2014, 02:05 AM   #2
0-60motorsports
here is some more info posted by my friend terra....
Originally Posted by 0-60Motorsports View Post
http://thebmwminipartstore.com
The part number is in M3Dragons list.....12517508831
Awesome. Now I just need to hunt down the various boots.
I found the one for the flap position sensor
12521732634
I found one that will work okay for the IAT and Actuator, but I'd prefer a 90-degree cap -- not able to hunt that down yet.
12521732694
Also having trouble finding the covering cap for the MAP connector
Oh and just so we have it on one page, here are the connector part number:
Flap Position Sensor - 12521427222
IAT and Flap Actuator Connector - 12521427615
MAP Sensor Connector - 12527507526
Old 06-26-2014, 10:48 PM   #3
Teslazerok
My Ride: 2003 M3 6SPD
Very nice, good job taking the time to gather the part #'s right down to the wiring boots.
Originally Posted by svtmike
Your TL is an eminently replaceable mass production inaninimate object that doesn't give a sh*t about you.
Teslazerok is offline   Reply With Quote
Old 07-06-2014, 05:00 AM   #4
0-60motorsports
Thanks Bud. Here to contribute to this community as much as we can.
