Sponsored by BimmerWorld
Old 07-02-2014, 09:36 PM   #21
Bavarian2009m3
My Ride: 2004 330ci
Will tackle install and report back. Thanks for all the help
Bavarian2009m3 is offline   Reply With Quote
Old 07-24-2014, 12:00 PM   #22
wallofgrath
My Ride: 2001 330Ci
Any update? I have same problem. I had my wheels balanced recently, replaced CAB's, and replaced struts.
wallofgrath is offline   Reply With Quote
Old 07-24-2014, 12:57 PM   #23
generalvp
My Ride: 05 330ci
Looks like I'm not alone in this vibration issue. I recently replaced my lower control arm with Meyle HD control arms with pre-pressed bushings and got the same steering wheel vibrations from 60+mph. Mine you, I also replaced the front struts and all its components, like shocks, upper strut mounts, upper/lower spring pad, upper spring mount, bump stops. Did 2 wheel balance and 2 alignments but still same result. I think the Meyle control arms and bushings are at fault because this did not happen before the swap.
generalvp is offline   Reply With Quote
Old 07-24-2014, 01:12 PM   #24
wallofgrath
My Ride: 2001 330Ci
Well I read that when you install new CAB's, it tightens it back up and can expose a vibration that would not have been noticed before. Still seems suspicious to me too! Maybe they are not all the way onto the arm? I'm going to have a shop re-balance my wheels, because Firestone probably did a half ass job.
Old 07-24-2014, 01:18 PM   #25
generalvp
My Ride: 05 330ci
Originally Posted by wallofgrath View Post
Well I read that when you install new CAB's, it tightens it back up and can expose a vibration that would not have been noticed before. Still seems suspicious to me too! Maybe they are not all the way onto the arm? I am going to rebalance my wheels. I'm going to have a shop re-balance my wheels, because Firestone probably did a half ass job.
I was told that I needed to pre-load the car before tightening the nuts. I didn't do that at first but went back and took everything apart, pre-load it and then tighten them but still same result. The Meyle control arms I bought were from oembimmperparts and came with the bushings pre-pressed. My next step is new front tires.
Old 07-24-2014, 07:21 PM   #26
generalvp
My Ride: 05 330ci
I am sure I have found out what was causing my vibrations. Check my thread:
http://forum.e46fanatics.com/showthread.php?t=1045902
Old 07-26-2014, 08:50 PM   #27
wallofgrath
My Ride: 2001 330Ci
I had all 4 wheels re-balanced today and it solved my problem. I guess Firestone did a bad balance job (only a few hundred miles prior to the vibration starting)
