Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 75 votes, 5.00 average. Display Modes
Old 08-23-2014, 06:54 AM   #101
Stak0
My Ride: 2005 M3 Convertible
Originally Posted by robuphill View Post
All fixed....i noticed the filter/fuse assembly on the fakra cable looked shoddy and badly made, cut it out and inserted an inline fuse and lo and behold it works a treat!!
Happy days
Stak0 is offline   Reply With Quote
Old 08-24-2014, 07:11 AM   #102
robuphill
My Ride: 330ci
Anyone know if there is a way to add widgets to the screen please?
robuphill is offline   Reply With Quote
Old 08-24-2014, 08:19 AM   #103
Stak0
I ditched the default launcher for Google Now launcher. Yeah yeah, I know it doesn't have the "advanced" functionality and options of other 3rd party launchers, but that's why I like it (in this particular case).
Old 09-19-2014, 02:58 AM   #104
Sopp
My Ride: E46 320td
hello, greetings from Poland . Can anyone tell me if it is possible to avoid drilling holes in the HVAC airbox, and fit this unit properly?
Edit. In my car I don't have to drill anything. Due to problems reported dy users, now they use curved connector for gps antenna.
Sopp is offline   Reply With Quote
Old 10-15-2014, 02:12 PM   #105
Nightwatch
My Ride: 330xi
Hello guys,
I just stumble over this on EBAY, anyone here used it ?
http://www.ebay.com/itm/ES9212MO-7-A...060768?afsrc=1
I really like how it looks vs the 9746A, and it seems to have gotten some upgrades also with some new buttons ? (HOME,BACK )
Anyways, if you have any news or feedback, plz post it
Kind Regards,
Nightwatch is offline   Reply With Quote
Old 11-29-2014, 03:34 PM   #106
Gatriel
My Ride: IS 250
Anyone else ever have horrible reception problems with this?
Gatriel is offline   Reply With Quote
Old 12-08-2014, 04:02 AM   #107
Sopp
My Ride: E46 320td
You mean FM radio reception? I have the same problem with my unit. On german e46 fanatics i've read that software update sometimes help, but i can't confirm this.
Old 12-08-2014, 04:07 AM   #108
Gatriel
My Ride: IS 250
I saw that as well. (I am on there under the same name)
After doing some digging, it appears that some of these all-in-one systems don't play well with our amplified antenna. I bought a glass mounted FM antenna and will mount it to the top of the Windshield or perhaps rear windshield drivers side -- just depends on how long the antenna cable is and routing possibilities.
Old 12-08-2014, 05:48 AM   #109
Sopp
My Ride: E46 320td
Please let me know if it helped. In my unit, radio reception outside the city practically is not an option (even for the biggest radio stations).
In Poland Erisin is not popular, and because of that there is no information on the local forums, so the question to you: does anyone updated the software and can tell what changes it results? I also want to connect a reversing camera - how complicated is it?
Old 12-08-2014, 05:58 AM   #110
Gatriel
My Ride: IS 250
Reverse camera should be pretty easy. There is a video input on the back of the unit, a power wire to power your reverse camera, and then there is a wire that comes off the back of the unit you tap onto the reverse wire, which tells the unit when the car goes into reverse. Its a good idea. I would love to do this -- but I'll do it at a later date.
I'll let you know. It gets done this Saturday.
I cannot even use my FM radio in city without unbearable static. IMHO this is the largest failure in the unit.
Dam ci znac.
Old 12-09-2014, 03:28 AM   #111
Sopp
My Ride: E46 320td
Dam ci znac.
Ok, thanks / Dziekuje
Old 12-13-2014, 05:42 PM   #112
cold m3
My Ride: E46 ///M3
Originally Posted by Nightwatch View Post
Hello guys,
Kind Regards,
This is just a re-branded Eonon GA5150 model. Eonon has it much cheaper right now. $375 group buy:
http://www.eonon.com/Car-GPS/Specifi...W/GA5150T.html
Photos of My ///M3
cold m3 is offline   Reply With Quote
Old 12-19-2014, 02:09 PM   #113
Gatriel
My Ride: IS 250
Just updated info with firmware update and how to
http://forum.e46fanatics.com/showpos...42&postcount=3
Old 12-19-2014, 06:39 PM   #114
Stak0
Is that one of those from XDA or from some different source?
All buttons work correctly? Push volume as "back" button?
I've got 4.4.2 from XDA but the MCU file I've found there isn't for this unit 'coz the front panel buttons don't work correctly although SWC and everything else does work fine.
Old 12-22-2014, 06:15 AM   #115
Gatriel
My Ride: IS 250
Sounds like you got your hands on a KDL mcu which screws everything up.
If you go back to the first page and grab the MCU I have listed in the third post, it'll fix everything up.
The new update.img is one I found accidentally digging through the "old" image releases. I tried the latest (4.4.4) and quickly went back to what I had listed.
Go to post three of this thread and read up there. Makes this unit awesome.
Old 12-22-2014, 07:23 AM   #116
Stak0
Nah, it's KGL but according to others, we need KGL1 mcu but I couldn't find KGL1 past 1.86. So I had to flash the only one they had there, which was KGL4.
I'm KIND OF happy with it because it made my front plate illumination work AND push volume as "Back" button. Now the illumination is always on, but I kinda like that anyway.
Every other *correct* mcu makes my buttons work correctly but the illumination isn't working.
I'll try your setup. I can always go back if I don't like it.
You say it "has been customised to cater as a driving unit, and not a tablet". Care to expand on this just a little or post a picture so we can compare the difference?
Old 12-23-2014, 01:55 PM   #117
Stak0
Ok, so I've tried it... and went back to my old setup. 1. No root, 2.Even if you switch to English, there is still some Chinese left, 3. MCU is perfect for our device, but I missed the "back" button too much, 4. I quite didn't like the launcher and yes, I know I could install a different one but the launcher was one of the main "selling points"
Nothing against your taste Gatriel, it's just not for me.
Old 12-27-2014, 03:38 PM   #118
Chilton88
My Ride: 325ci, 325xi
Hi, has anyone installed a better app bluetooth music player that displays the music information such as artist name and song title?
Chilton88 is offline   Reply With Quote
Old 01-10-2015, 12:57 PM   #119
Ezekial
My Ride: 330D E46
Hi,
I was wondering if anyone could possibly help me.
I have owned an Erisin es9746 for around 3 months or so. I decided to try today to install a USB webcam as a dash cam but the apps would not recognize the camera so I thought I would try to install the update Gatriel posted. (http://forum.e46fanatics.com/showpos...42&postcount=3)
The installation appeared to go fine it went into the recovery mode screen and the progress bar was going along. Eventually the device turned itself off (i had the engine running during the install) and now when it boots it shows the Navigation system logo and says Kitkat 4.4 on the top left but then it just gets stuck on a spinning android logo forever.
Do you have any ideas on how I could fix this?
Thanks a lot for any help!
Ezekial is offline   Reply With Quote
Old 01-10-2015, 12:58 PM   #120
Gatriel
My Ride: IS 250
Originally Posted by Ezekial View Post
Hi there,
I was wondering if you could possibly help me.
I have owned an Erisin es9746 for around 3 months or so. I decided to try today to install a USB webcam as a dash cam but the apps would not recognize the camera so I thought I would try to install this update.
Never had this issue. Does the unit turn off when you turn the car off -- or does it stay on?
If it does -- then I would try and reload the software.
