Xenon bulb going out sporadically - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-06-2014, 10:38 PM   #1
Qtonic
My Ride: M3
Is it normal for a Xenon bulb to slowly go bad? My driver side bulb recently was out and the dash warning light came on to indicate it. I looked up bulbs and was just about to order some.
Then the next time I drove it was working fine and no light on the dash. Later it didn't work. Another time it did and so on. Been this way for about 5 days.
I'm happy to order new bulbs if that's what I need, but I don't want to do it if this behavior indicates that isn't what's at fault.
Qtonic is offline   Reply With Quote
Old 07-06-2014, 10:47 PM   #2
cscracker
My Ride: 2004 330Xi
This is normal for a bulb failure, you'll also notice them being very flickery and the color being off and dim (usually purple or reddish). It can also be caused by the ballast going bad, though.
cscracker is offline   Reply With Quote
Old 07-06-2014, 10:50 PM   #3
Qtonic
My Ride: M3
Thank you!
Old 07-06-2014, 11:32 PM   #4
cvx5832
My Ride: 325Ci, 325Cic, C300
Normal failure mode for xenons when they get old. Google "xenon cold start failure". Replace with QUALITY units.
cvx5832 is offline   Reply With Quote
Old 07-07-2014, 04:34 PM   #5
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Just make sure it's the bulb. I would swap the bulbs around and see if it persists with the bulb. If not you might have an ignitor and ballast issue. If it is the bulbs then you can get Philips 85122+ bulbs from theretrofitsource.com and if you want the best and can afford it there are the Osram CBI (which I have)
Old 07-07-2014, 05:32 PM   #6
Qtonic
My Ride: M3
The Osram bulbs look nice. What color temp do you recommend?
Old 07-08-2014, 03:35 AM   #7
bkina
My Ride: E46 330Ci // E36
I currently have the same issue, I switched the bulbs around but the issue remains the same. It turns on after I turn the car off and on again, might look into one of the other fixes mentioned..
bkina is offline   Reply With Quote
Old 07-08-2014, 06:16 PM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
For a real xenon bulb there's only 4300k or 5000k. 4300 is yellow/white while 5000k is more pure white. It depends how much you want to spend $95 or 180 but the brightness of the CBI are a bit more.
Old 07-12-2014, 03:13 AM   #9
Qtonic
My Ride: M3
I decided to be different and went with Philips' new 85122 XV 'xtreme vision' bulbs. They're supposed to compete with the Osram CBI's in that they give ~5000k light that's about as bright as 4300k. Same price range as CBI, fyi.
Unfortunately I'm not too impressed with them in my 03 M3. I think it's the combo with the lenses, but they give off a distinct green light. It's brighter for sure, but I just find it ugly through the e46 projectors. Bummer. Wishing I had purchased the CBI's I guess.
Anyway, I just wanted to follow up. Maybe I'll try to sell them. I bet they're better in other cars.
Old 07-12-2014, 03:50 AM   #10
Solidjake
Zero. Leaks.
Solidjake's Avatar
The glass on your projectors are frosted with a line going through them? If so swap out to ZKW lenses
Old 07-12-2014, 11:02 PM   #11
Qtonic
My Ride: M3
Looks like I'm headed down the rabbit hole with this project. Sigh. Ok I'll order the ZKW lenses. Thanks for the recommendation.
While I'm in there I think I'll add some angel eyes. Any opinions?
