///M3 Forum
Old 07-07-2014, 04:29 PM   #1
samibmw
Smg transmission
Hello everyone,
I
About to buy a 2003 M3, a lot of people scared me about the SMG trani. Any ideas or personal experience. Thank you so much.
samibmw is offline   Reply With Quote
Old 07-07-2014, 05:26 PM   #2
SKR7
My Ride: E46 MY04.5 SMG M3
I've got a 2004 M3 with SMG. Some hate them, some love them. From my experience its not the best transmission around but then it was designed quite some years before the current tech. when you are on it, it is awesome. At low speed (in traffic) its not all that. If you can find a manual go for that. But the SMG is a very decent alternative. It was put into the CSL exclusively, for good reason.
///M
2004 E46 M3
SKR7 is offline   Reply With Quote
Old 07-07-2014, 06:04 PM   #3
Cbaty08
My Ride: '06 M3 SMG ZCP
If you live anywhere it gets hot, I'd suggest going with the manual; I say that as right now I am having to order the SMG tranny temp sensor, as the tranny likes to pop into neutral when it sits at stop lights on hot days...
But, if it is cooler where you live, I'd say go for it! They are very fun once you get them 'down'.
Cbaty08 is offline   Reply With Quote
Old 07-07-2014, 06:13 PM   #4
samibmw
Thank you so much for your insight. That was really helpful
Old 07-07-2014, 06:16 PM   #5
SKR7
I'm in Sydney. Never ever had an issue with heat and the SMG. Combined with the crap traffic you'd imagine there would be a problem. But no.
///M
2004 E46 M3
Old 07-07-2014, 08:04 PM   #6
IE/M3
My Ride: 2003 M3 Conv
Hello- I've had my E46 M3 vert for about 6 months....I had 1 issue with my SMG, It wad 108 degrees here in the inland empire and was playing around in sport mode. Got the dreaded cog light, cleared up after letting it cool of with no issues moving forward. Today was 103 and with normal driving it was fine, I have to say I like the SMG...we have tons of traffic and 6spd is more fun and engaged but the SMG helps me tolerate traffic and can have some fun.
IE/M3 is offline   Reply With Quote
Old 07-07-2014, 09:10 PM   #7
wrig42
My Ride: 03 M3 E46 SMG
I just bought an 03 m3 with an smg. I had a sensor issue was cheap to fix and since then no issues. Takes some getting used to I'll admit but def is great if you sit in traffic a lot.
wrig42 is offline   Reply With Quote
Old 07-07-2014, 11:16 PM   #8
Mddicted
My Ride: M6
Just don't spend your last penny buying the car, plan for a reserve fund. Do not purchase any used car without a warranty or a PPI. The best $200 i spent before I bought my car.
SMG was built to drive hard and that is when it performs best. Never downshift into first, let the car do it. You will get the bucking bronco a couple of times until you learn how to start from a stop. Just stomp on the gas or click up a gear. Get out on a track and experience what the car was built for.
Good Luck!
2005 Silver Grey Metallic / Imola
Competition Pkg
Slick top
Active Auto Werke Headers
Rogue 3" Race Exhaust w/Y pipe
Dinan 3.91
KW Clubsport 3 Way Coil Overs
Rogue Adjustable Rear Camber Arms
Fluidyne Aluminum Radiator
Rogue Aluminum Oil Cooler
AKG Solid Motor and Transmission Mounts
UUC Organic Clutch Kit w Aluminum Flywheel
Brembo calipers with OEM Comp rotors
PFC 08's
Nitto NT01's 18" Sq on Apex Arc 8's
Mddicted is offline   Reply With Quote
Old 07-08-2014, 04:22 PM   #9
Teslazerok
My Ride: 2003 M3 6SPD
There's a known fix for the heat issue. It only requires wiring in a resistor. Super easy fix.
It's still a manual transmission, so don't expect it to drive like an automatic, you still need to rev match, etc, for it to be smooth.
It is dated in terms of technology so it isn't perfect, but you can update it with CSL software and this will majorly improve the shifting at all rpms. There's info on this on the m3f coding section.
I think the bad reliability of the transmission is over exaggerated. Mostly due to a lot of people/shops not knowing how to fix/diagnose it.
Originally Posted by svtmike
Your TL is an eminently replaceable mass production inaninimate object that doesn't give a sh*t about you.
Teslazerok is offline   Reply With Quote
Old 07-08-2014, 04:55 PM   #10
Cbaty08
I've read about that 'band-aid', but am going to see if fixing it the proper way works; I'm going to have her opened up to replace my starter anyways.
I agree that the SMG can be a very good tranny; that is the reason it is the ONLY option for the CSL.
Thanks for the tips though!
Old 07-08-2014, 10:31 PM   #11
jeffrey262
My Ride: M3 Convert & M5
Ive owned my m3 since 2006. I have 60,000 on the car. I purchased it with 7500 miles. I have never had a heat issue but the bucking Bronco yes. Once you get use to driving the SMG, you will love it. I prefer to shift myself and allow the tranny to downshift on its own. The automatic shifting stinks. There always seems to be a slight hesitation. I use the dial down controller to increase / decrease the shifting. I have never had a problem with my m3. No parts replaced only recalls. Good luck selecting SMG or manual
jeffrey262 is offline   Reply With Quote
Old 07-08-2014, 10:51 PM   #12
Cbaty08
SMG that's never had the heat issue that makes it pop into neutral? GO BUY A LOTTO TICKET!
Old 07-14-2014, 02:08 PM   #13
jeffrey262
I did not know there was a issue.
After I posted how I have never had a problem, I need new front calibers, rotors, and brakes on the front after I brought my car in for a bad vibration problem. Front left caliper stuck half closed. Left wheel would not spin while it was on the lift. $2,000 to repair.
