///M3 Forum
Old 07-08-2014, 12:32 PM   #1
CierasM3Dinan
My Ride: 2003 Dinan M3
M3 Delaying when starting
I have a 2003 m3.
It had started taking a few cranks to start the car. I can hear it turn over but wont full start. I had the fuel pump changed 6 months ago and checked recently and everything is okay with it and starter & alternator was check and its okay. Anyone had this problem or know what it could be? Thanks
CierasM3Dinan is offline   Reply With Quote
Old 07-08-2014, 01:53 PM   #2
isaim3
Is the Check engine light on?
isaim3 is offline   Reply With Quote
Old 07-08-2014, 02:06 PM   #3
CierasM3Dinan
Yes
Old 07-09-2014, 10:15 AM   #4
isaim3
You should probably get your codes read. Maybe at autozone. I'm having the same issues. I'm assuming the crank position sensor.
