Sponsored by The Tire Rack
Old 07-08-2014, 04:14 PM   #1
ijoelpod
My Ride: 2002 325i
17" wheels on stock non sports suspension
Total Noob here, but I have a 2002 325i with stock non sport suspension and 16" wheels. I need new tires and I want to run 17's on my car. My question is would I have to alter the suspension?
ijoelpod is offline   Reply With Quote
Old 07-08-2014, 04:33 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
No.
Post up what your current tire size is, & what you want to go to.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 07-08-2014, 04:38 PM   #3
ijoelpod
My Ride: 2002 325i
Originally Posted by Rob43 View Post
No.
Rob43
my current tire size is 205 55 16, and I want to go to 225 45 17. I used the tire calculator and it seems there wouldn't be too much of a difference.
Old 07-08-2014, 04:45 PM   #4
Rob43
Rob43's Avatar
That will work just fine.
As a note, a 330Ci comes in many cases with the M68 wheels. I mention this because they are F 17x7.5, R 17x8.5 so the Front tires are 225/45-17 & Rear 245/40-17
All of this depends on what Width wheel you go with.
Rob43
Old 07-08-2014, 04:49 PM   #5
ijoelpod
My Ride: 2002 325i
Rob43
So if I want to go with 225 45 17 size tire all around , what is the general wheel width I should be looking for?
Old 07-08-2014, 05:08 PM   #6
Rob43
Rob43's Avatar
17X7.5 is spot on. But 7" to 8.5" works. I have no idea what your budget is, but if you can afford light weight wheels, this will be a performance upgrade.
Rob43
Old 07-15-2014, 02:56 PM   #7
avincent52
My Ride: 325iT 5 speed/Sport
Rob43
One of the advantages of square setup (all 4 wheels/tires the same width) is that you can rotate the tires to maximize tire wear.
With a staggered setup (rears wider than fronts) you can't do that.
A friend also suggested that in a stock 325, the staggered setup made the handling worse by increasing the natural understeer.
avincent52 is offline   Reply With Quote
