Sponsored by The Tire Rack
Old 07-11-2014, 11:28 AM   #1
Romanek
My Ride: 2004 330ci ZHP 6spd
Fitting 19x9.5 et35 rims on the front of a 2000 323ci vert
Hey guys, I have a set of 4 enkei raijin 19x9.5 et35 rims and I'm looking to fit them on my 2000 323ci vert with a non-sport suspension. Right now I'm running style 79 17x8 et47. I know that the enkeis will fit real nice in the rear, but I'm worried about rubbing issues in the front. Has anyone ran 9.5 wise rims in the front of a non-m 3series?
Romanek is offline   Reply With Quote
Old 07-11-2014, 12:49 PM   #2
lamsv
My Ride: 2001 325iT
I ran a 18x9.5 et25 on the front of my sedan. I had to run a 225 wide tire, rolled front fenders, and -3 degrees of camber. You might actually run into clearance issues between the wheel/tire and your suspension with a 9.5 et35 wheel.
lamsv: 2001 HELLROT on BLACK 325iT
lamsv is offline   Reply With Quote
Old 07-11-2014, 01:44 PM   #3
Romanek
Would being at stock ride height on a stock suspension help? I know a guy running 19x9 style 95's on racelands and he says he doesn't rub. Any idea if I could correct it with spacers?
Old 07-11-2014, 02:42 PM   #4
lamsv
My Ride: 2001 325iT
On stock suspension, you shouldn't have clearance issues to the suspension. You shouldn't rub on the fender either. BUT. Your wheels are going to poke. A lot. It won't look good at all.
To run aggressive wheels and make it look proper, it takes a lot of work. Rolling fenders, adding camber, stretching tires, etc.
Old 07-11-2014, 02:57 PM   #5
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
The other thing you might be missing is the fact that 19" wheels ride like crap on our Bimmers. Most guys that get them, sell them later for 18" wheels and are much happier.
Good luck,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 07-11-2014, 03:13 PM   #6
Memlol
My Ride: samsquatch
Good luck,
Rob43
Only way I'd ever go to 18s is if/when I get fender flares for some 18x11/18x12s.
The difference from 19 - 18 is exaggerated
Memlol is offline   Reply With Quote
Old 07-11-2014, 03:25 PM   #7
Romanek
I'm planning to run 245/35/19 tires and I'm going to roll the fenders next week.
Old 07-11-2014, 03:44 PM   #8
Romanek
Thanks guys this was very helpful and what I was looking for.
Old 07-11-2014, 04:02 PM   #9
Memlol
My Ride: samsquatch
245/35 is too big for the front IMO. Will end up looking like a 4x4 especially on stock suspension.
Old 07-11-2014, 04:16 PM   #10
Rob43
Rob43's Avatar
It sounds like you need to do a little more research.
Rob43
Old 07-12-2014, 09:15 AM   #11
tcphoto
My Ride: E92 335 MT Coupe
Why is it most of the 19" wheel questions are posted by new members?
tcphoto is offline   Reply With Quote
Old 07-13-2014, 04:43 PM   #12
cd330
ModZombie Moderator
cd330's Avatar
My Ride: SG E46, AW F30
it's because they are new and don't know how to search.
cd330 is offline   Reply With Quote
Old 07-15-2014, 04:12 PM   #13
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
19X9.5 ET35 is extremely aggressive up front without a stretched tire on a 323 vert, even with camber changes and mods. Strongly suggest you resell those wheels and start over with a more appropriate size.
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
19, 9.5, enkei, front
