Old 07-12-2014, 08:50 AM   #1
jackson691
My Ride: 3 series
only starts as n wen
Hi i jus bought a 2.2 320 n recently started problems with it starting the battery is all good had it drop tested n all gd but wouldn't start other day so put it on charge n after about 10 mins the charger sed it was fully charged so put back in car n it started n will do all day but try n start it next day n i have to start the same process puttin in on charge for 10 mins etc etc n if if don't start wen im out i have to get a jump start i no it seems a really bizarre issue does anyone have any ideas
jackson691 is offline   Reply With Quote
Old 07-14-2014, 01:37 PM   #2
Tangent_
My Ride: '01 330i, '11 Z435i
If I translated... that... into English correctly, it sounds like you have a parasitic load on your electrical system that's discharging the battery overnight. Follow these directions to track it down: http://www.wikihow.com/Find-a-Parasitic-Battery-Drain
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 07-14-2014, 01:59 PM   #3
emgee
My Ride: 3 pedal 2005 325xi
emgee is offline   Reply With Quote
Old 07-14-2014, 04:55 PM   #4
SoloII///M
My Ride: Many
Unless the battery was load tested and proven to be good I'm suspecting the battery is the culprit. Parasitic draws are easy to look for, though, so do that first.
John V
'02 330Ci - Megasquirt 3 tuned by PFTuning.com
SoloII///M is offline   Reply With Quote
Old 08-13-2014, 02:53 PM   #5
Das_e30
My Ride: 2000 328ci
Originally Posted by emgee View Post
lol
Das_e30 is offline   Reply With Quote
