Old 07-12-2014, 07:31 PM   #1
Dirtybrd
My Ride: 02 330ci
High beams??
Are both inner and outer lights supposed to light up on high beam? My inner lights do illuminate for DTRL and if I pull the stalk back for flash to pass, but only the Zenons light up in the high beam position.
Dirtybrd is offline   Reply With Quote
Old 07-12-2014, 08:24 PM   #2
franz
My Ride: 03 330i
That is how the bi-xenons work, which is what you have.
franz is offline   Reply With Quote
Old 07-12-2014, 10:04 PM   #3
ELCID86
My Ride: 2004 330i (ZHP) x2
You can turn off DRLs and otherwise alter the lighting with coding.
iPhone and BimmerApp
Shawn in VA (USA).
- Shawn's 2004 IR/Alc. w/6MT ZHP (1/351 built)- http://bit.ly/1nhx4gk
- Colin's 2004 OB/Sand w/6MT ZHP (1/25 built)- http://bit.ly/1qT1tT1
- Shawn's 2004 OB/NB w/AT ZHP (sold)
ELCID86 is offline   Reply With Quote
Old 07-12-2014, 10:20 PM   #4
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Xenon lights on
push stalk: shutter in xenon projector opens, allowing full/high beams
pull stalk: flash to pass; inner DRLs become brighter
stalk neutral: shutter in xenon projector closed, blocking the upper part of the beam for low beams
Old 07-13-2014, 08:46 AM   #5
Dirtybrd
My Ride: 02 330ci
Thanks guys, I did a little more reading on them after I posted. Seems like a waste of a light. Can it be coded to function with high beams, or just rewired?
Old 07-13-2014, 10:04 PM   #6
Jmanscotch
My Ride: makes my pants tight
http://forum.e46fanatics.com/showthread.php?t=895209
Do it.
-Jake
2004 325CI - 2003 3.0 Z4 - 1994 325i - 1967 1602 - 2008 328XI - 2009 135i - 2007 Jeep Wrangler - 2014 *Loading*
Jmanscotch is offline   Reply With Quote
Old 07-13-2014, 10:15 PM   #7
ti317
My Ride: 02 330ci coupe 5 spd
You can program both halogens and xenons to stay on when on high beam. I did mine a long while ago but if you have NCS Expert, let me know and I'll search for the coding.
The only difference between death and taxes is that death doesn't get any worse every time Congress meets. - Will Rogers
ti317 is offline   Reply With Quote
Old 07-13-2014, 11:03 PM   #8
330i ZHP
330i ZHP's Avatar
My Ride: have 5 doors and FI
it can be coded - and you can have the fogs on with high beams...it LIGHTS up the night
/_________\
O==[][]==O
Old 07-14-2014, 06:37 AM   #9
ti317
Here is how it's done:
Look for PWM_WERT2_FL_BIXENON in the ALSZ module. Set it to wert_01
That just gives you the halogens on with brights. Fogs on with brights will get you a ticket.
Old 07-14-2014, 09:03 AM   #10
Dirtybrd
My Ride: 02 330ci
I don't have NCS, how do I go about getting it and what type of adapter do I need to connect to the car?
Old 07-14-2014, 09:09 AM   #11
Guest021715
Account closed.
eBay for the cable and the internet for the software.
Sometimes the cable will come with software depending on the seller you buy from.
The hardest part is setting it up, however this should help:
http://forums.bimmerforums.com/forum...ith-NCS-Expert
Old 07-14-2014, 11:10 AM   #12
LeMansteve
High beams and fog lights serve two opposite purposes, so it's kind of pointless to have them lit up at the same time.
Old 07-14-2014, 02:03 PM   #13
Guest021715
Account closed.
Not at all.
I can see if anything is lurking in the sides, about to jump out in front of my vehicle, while also having excellent distance visibility. Not to mention I can better assess the black wet asphalt on rainy days.
"Fog" lights are useful in many circumstances besides foggy conditions.
Old 07-14-2014, 07:56 PM   #14
Dirtybrd
My Ride: 02 330ci
Like this?
http://www.ebay.com/itm/BMW-USB-OBD-..._Tools&vxp=mtr
Old 07-15-2014, 05:39 PM   #15
ti317
That should do it.
Old 07-16-2014, 04:44 PM   #16
Dirtybrd
My Ride: 02 330ci
Originally Posted by ti317 View Post
That should do it.
Thank you!!!
