Thread Tools Search this Thread Rating: Thread Rating: 27 votes, 4.89 average. Display Modes
Old 07-13-2014, 09:59 AM   #1
daniel_f.
My Ride: 330iC
Deciphering MS43, an open approach!
Say thank you to HakenTT aka revlimit aka Wolfowitz aka wolfow
Old 07-13-2014, 12:13 PM   #2
daniel_f.
My Ride: 330iC
I´m currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 07-13-2014, 04:09 PM   #3
Harry330
My Ride: 330Ci
I will say i personally don't no much about bmw computers, but i wanted to say good job. Keep up the Great Work!
One Of Many Goals.
Harry330 is offline   Reply With Quote
Old 07-13-2014, 06:21 PM   #4
HakenTT
My Ride: 323i with S54
Not sure why?
Siemens MS43 tuning master
HakenTT is offline   Reply With Quote
Old 07-13-2014, 07:19 PM   #5
unevolved
My Ride: 2003 325i
I wish there was something I could do to help, but I'm really glad you're doing this. If non-M's could be tuned easily, the aftermarket would explode and we'd all benefit.
In a bacon and egg sandwich, the chicken is involved, but the pig is committed. Be that pig.
unevolved is offline   Reply With Quote
Old 07-13-2014, 07:19 PM   #6
unevolved
My Ride: 2003 325i
If there's any tasks a mechanical engineer would be good at, let me know. I'm very interested in seeing this done, but I don't have the skills to do it.
Old 07-13-2014, 07:25 PM   #7
HakenTT
Originally Posted by unevolved View Post
I wish there was something I could do to help, .
Yes there is. Don't post if there is nothing you have to contribute, thread gets loaded with worthless posts
Old 07-13-2014, 08:00 PM   #8
unevolved
My Ride: 2003 325i
Goddamn dude, nevermind. There's a ton of aborted threads out there that people abandoned because people lost interest. Just trying to encourage OP to finally decipher and publish this.
Old 07-13-2014, 08:01 PM   #9
Thaniel
My Ride: 06 E90, 01 330
Originally Posted by daniel_f. View Post
thank Thaniel for his awesome work and help.
You are welcome. Without that MS430056 data file We wouldn't have been able to unlock the info. I'm glad to see you are willing to share the information. Since it was based on MS430056 extract you found I wasn't sure I should post it.
For the real enthusiasts like me, lets keep sharing and collecting whatever is found.
Yes let's. Perhaps I should add here that when I matched the MS430056 to another .bin Daniel provided I also matched it to my 2001 330i's .bin. No they did not share addresses but I added another set of columns and massaged the addresses in the same fashion. So I have another A2L to share. Once I figure out what version number it is I'll post it on my google drive (the .bin is already there).
While I'm typing perhaps I'll mention a few things about the data matching. The first thing I do is extract the axis points. Preceding each axis data set is a length byte (or word or long). With the length byte the whole string of axis points can be extracted from the .bin. If the data in the axis is word length the length byte is word length. All 3 .bins start the axis bytes at 74001 (74000 being the length byte). But each .bin has a different amount of axis. For example in my car the axis points match in length and nearly identical values from 74001 to 74087. the next axis point in the 056 is 6 bytes long (we have the length bit telling us how long it is) and in my car is 4 bytes long. So no match. Looking at the length of the following axis points lengths and axis data (in hex) it becomes obvious that my car is missing the next axis. And if I shift the data down to the next axis point the 2 match again. This miss matching happens about 40 more times in the list of axis points. It is worth noting. It could have been the axis itself and the corresponding map is smaller. This happened in my 328i to 323i conversion (and it makes a real mess). But luckily in this data set it appears that if the map existed in the ECU it was the same size. Making it easier to match maps, curves and axis.
My point is it's not just a matter of shifting the beginning point of the data. As if there is any extra data or less data in the stream then it is all jumbled as soon as there is a difference.
With the Maps and curves and values there is no length byte. the matching I do is purely looking for similar values in the stream and matching them up. Once aligned enough of the bytes match to make it obvious it is correct. then once things do not match it's obvious too. In the transition area there can be some guessing. But the error rate I think is a pretty low %. But if one of the error spots is in the map or value you are interested in.......Well we'd have to look at it.
Anyway. That's how I align the various .bin's to each other. Once the .bins are aligned the matching A2L gives us what the values mean. I make extensive use .xls sheets to make things easier and more visual but there is still some hand manipulation. Oh and I shouldn't leave this out. My son Garrett put in many hours matching curve and map data after I set up the .xls sheets. It was not all done by me. :-)
Thaniel
My LS1 V8 into E36 and then E46 Blog
www.LS1BMW.blogspot.com
Thaniel is offline   Reply With Quote
Old 07-13-2014, 08:10 PM   #10
Thaniel
but to me it`s weird they made german entries in an english Damos file...
I'm pretty confident it was originally all German and at some point only a portion of it was translated to English.
Thaniel
Old 07-14-2014, 12:02 AM   #11
daniel_f.
My Ride: 330iC
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 07-15-2014, 02:24 PM   #12
daniel_f.
My Ride: 330iC
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 07-16-2014, 07:06 AM   #13
Thaniel
Took a moment this morning and reorganized and added to my google drive
https://drive.google.com/#folders/0B...VZCQk02X1NWZTA
It now has A2L's for versions
MS430037
MS430056 - Original A2L
MS430066
In process is the MS430055 and MS430069
Also included is a correspoinding ECU dump in .s28 format (the format ASAP2Demo likes)
***For those not familliar with what is going on, I will take a stab at providing a little direction. Following is a summary of how to read the information on the drive.***
To read the A2L's open with a A2L compaitble reader like ASAP2DEMO (Free) or WinOLS (Very expensive, WinOLS free version is not A2L compatible). Then load the corresponding ECU dump (full dump).
What if you want to load your own ECU's dump? Extract a full dump. Usually this is saved as a .bin. Use a hex editor to export it into a .S28 file. and do the above.
***For those with questions of how to delete EWS, IMMO ****
Those are not done trough the OBDII port. You have to remove a surface mount EEPROM from the ECU board and program with an EEPROM chip programmer. This, I believe, is beyond the scope of this thread.
Old 07-16-2014, 07:23 AM   #14
Thaniel
made some steep progress and beginning of listing important maps to start with.
Ah I see you edited post number 2. Great descriptions. I'll have to see if they will fit into the comment portion for each map in the A2L.
Old 07-17-2014, 07:14 PM   #15
Thaniel
MS430037
MS430066
Added the 055 to the drive and updated the 037 and 066. Having a 3rd dump to compare against cleared up some of the "grey" areas.
If a map did not exist in that version I set the Address to 0x0000 but stray data will show. So glance at the address if map looks weird.
Thaniel
Old 07-18-2014, 07:38 AM   #16
unevolved
My Ride: 2003 325i
That procedure sounds similar to modifying other ECUs I've worked on. If it's possible to burn new chips with something like this, it could be doable by the average Joe. That sounds promising.
Old 07-18-2014, 09:02 AM   #17
Thaniel
The EEPROM chip is surface mounted and, in my opinion, is very difficult to remove (I'm not interested in removing it). And man are those pins small. 90% of what the average joe wants to change is updateable through the diagnostic bus (TXDI) which is available at the OBDII port on E46's since mid 2000 (on the 20 pin prior to that).
With that said I've bought a chip programmer and my son has been busy trying to figure out how to make it work with a blank 29F400BT chip (The programmer we have only works with XP and programms through the parallel port. Despite having a USB port on the board. Had to dig through the old computer pile to get the right equptment.). But that's a topic for another discussion. I may post on my blog what we learn. Will depend on how far we get.
Thaniel
Old 07-18-2014, 09:17 AM   #18
Thaniel
Maybe interesting maps found:
[*]basic ignition advance:
ip_iga_ron_98_pl_ivvt__n__maf[/LIST]
I thinkt the RON_98 was originally roz98 or 98 octane. There is also a map "ip_iga_ron_91_pl_ivvt__n__maf" Which I believe is the same thing but for 91 Octane (don't tell those folks that think BMW's shouldn't run on anything but premium).
The MS42, which didn't have the english translation mess, I think the two correspoinding maps are:
kf_zw_roz91_vanos_tl__n__lm
kf_zw_roz98_vanos_tl__n__lm
Which I roughly translated to
kf_timing_91 Octane_vanos_Part Throttle__RPM__Airflow__
kf_timing_98 Octane_vanos_Part Throttle__RPM__Airflow__
Right or wrong? What do you think? What does ip or kf stand for?
Thaniel
Old 07-18-2014, 09:40 AM   #19
daniel_f.
My Ride: 330iC
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 07-18-2014, 11:59 AM   #20
Thaniel
Your absolutely right, but as Alpina didn´t touch the 91octane map, i don´t see any reason to change that. I have it on my personal list, but i don´t think its wise to edit them.
KF means Kennfeld, which translates to "map" or "table". ip_* is exactly the same, even so i don´t have any clue how they translated kennfeld into anything starting with "i"
Removing the 93C86 is pretty straight forward for someone with soldering skills and very easy with a hot-air gun.
Knowing what to change within that eprom is something more difficult, as i don´t have any clue whats going on in it.
(edit)
actually i´d say this:
Kennfeld_Zündwinkel_Roz91_Vanos_**__abhängig-von-Drehzahl__abhängig-von-Luftmasse
which translates to Map_Ignition-advance_related-on-ROZ91_don´t-know-what-Vanos-has-to-do-here__based-on-rpm__based-on-airflow
i wouldn´t trust tl to be Teillast or partial load unless you have verified the axis are not up to their max values. if, e.g. n is going up to 6500rpm, you can easily bet its not partial load.
Good stuff. ok so Kf = Kennfeld = Map. I'll add that to my MS42 decode ring :-)
Now what is this map for. That is a good question and what we really need to discover on as many maps as possible. This is my take on it.
The units for the axis are in mg/stroke and RPM. or in other words Airflow vs RPM. Think that covers the "based on RPM and airflow" portion clearly. The values are in Crank angle. So it definately appears to be a timing map. But is it ignition timing or vanos timing? I don't get the reference to Vanos Are the values absolute values or offsets?
As far as the "tl". I do not belive "tl" means less than full RPM. Just not full load. I interpret this to mean the the throttle plates are not full open. I could be at max rpm with very little throttle opening if there is little load. Perhaps full lload is the base and these are just offsets when it is part load?
Other intersting thoughts. In the MS42 this map is also present (looks like ip_igab__n__maf or ip_iga_tco_1_pl_ivvt__n__maf in the MS43)
kf_zw_tkw1_vanos_tl__n__lm
Which I had interpreted as:
kf_timing_Map1_vanos_Part Throttle__RPM__Airflow__
Not sure how it is used differently from the previous mentioned ones that included Roz. But values are simlar
And to make some comparisions against the "part throttle" threre are 2 other similar maps but with "idle air" instead of "part throttle":
kf_zw_tkw1_vanos_ll__n__lm
kf_timing_Map1_vanos_Idle Air__RPM__Airflow__
kf_zw_tkw2_vanos_ll__n__lm
kf_timing_Map2_vanos_Idle Air__RPM__Airflow__
There isn't a full throttle map but expect the timing of whatever it is handled a different way at full throttle. But I could be completely wrong.
My head is starting to hurt Think I'll go back to translating A2L's for a bit :-)
