Thread Tools Search this Thread Rating: Thread Rating: 27 votes, 4.89 average. Display Modes
Old 07-18-2014, 12:37 PM   #21
daniel_f.
My Ride: 330iC
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 07-18-2014, 03:49 PM   #22
Thaniel
My Ride: 06 E90, 01 330
Originally Posted by daniel_f. View Post
Maybe we should start a new thread on deciphering MS42? I guess its getting confuse if with mix both ecus. i need to see the maps and the axis to try to translate them, thats what made most sense to me.
I already have a MS42 thread. That's not the point. Point is the MS43 map names we have are a translation, possibly incorrect translation, of a German original A2L (obviously not done well as it was not completely translated). The Maps, if it exists in another BMW ECU, with the unaltered German titles, might give better information. Or at the very least another clue to the use of the map. To me this is the same as looking at a MS430055 data dump trying to interpret a MS430037. Or looking at the S54 Data to get ideas on what MS43 data might have in it.
Forgive my error in bringing up other data beyond the one ECU.
Thaniel
My LS1 V8 into E36 and then E46 Blog
www.LS1BMW.blogspot.com
Thaniel is offline   Reply With Quote
Old 07-18-2014, 04:39 PM   #23
daniel_f.
My Ride: 330iC
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 07-19-2014, 02:09 PM   #24
daniel_f.
My Ride: 330iC
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 07-21-2014, 12:51 AM   #25
328ijunkie
My Ride: E36,E30
Youd be surprised what its aware of
328ijunkie is offline   Reply With Quote
Old 07-21-2014, 01:14 AM   #26
daniel_f.
My Ride: 330iC
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 07-21-2014, 01:36 AM   #27
t651
My Ride: BMW
Was INPA listing that in error in shadow or active faults?
t651 is offline   Reply With Quote
Old 07-21-2014, 01:52 AM   #28
daniel_f.
My Ride: 330iC
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 07-21-2014, 03:16 AM   #29
HakenTT
My Ride: 323i with S54
I got no dtc in ScanMaster-ELM, but the maf code appeared within INPA
Because scanmaster is generic Eobd reader and INPA reads factory BMW codes only. This means you deleted generic codes but not the factory codes. Generic codes are not the same as factory codes, that is well known so I doubt you are german.
Siemens MS43 tuning master
HakenTT is offline   Reply With Quote
Old 07-21-2014, 07:04 AM   #30
Thaniel
Originally Posted by Thaniel View Post
Took a moment this morning and reorganized and added to my google drive
https://drive.google.com/#folders/0B...VZCQk02X1NWZTA
In Laws were visiting over the weekend so I had lots of time on my hands. So finished the MS430069 (and pulled a transmission and engine from one E46 and another engine from another E46.)
There is now a taylored A2L for the following versions on my google drive.
It now has A2L's for versions
MS430037
MS430055
MS430056 - Original A2L
MS430066
MS430069
As a BONUS. I uploaded the file I used to align the addresses. So this has the address & name of the item in the A2L (Value, curve, map etc) with up to the first 16 bits of data shown. All side by side. Makes comparision between versions pretty easy. I think most everything is aligned pretty good except the portion of the MS430037 in the 42000 range. It is either radically different in values or doesn't exist.
Screen shot from the .xls sheet below (sheet is ont the google drive)
Hope this is helpful.
Thaniel
Name:	Addresss comparisions.jpg
Old 07-21-2014, 07:09 AM   #31
Thaniel
Hello Hakan,
Thanks for your input. Might want to consider that Germans aren't born with a knowlege of BMW's. So I don't see how this factors into where he lives.
Thaniel
Old 07-21-2014, 08:50 AM   #32
daniel_f.
My Ride: 330iC
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 07-21-2014, 10:55 AM   #33
t651
My Ride: BMW
Youve already done a xdf?!
I too second the awesome work on this.
I've loaded the XDF against a MS430056 version I was adapting/working.
The map locations are perfect!
It loads directly into TunerPro and works immediately on partial reads with a 0x70000 offset
Old 07-21-2014, 11:53 AM   #34
daniel_f.
My Ride: 330iC
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 07-21-2014, 12:15 PM   #35
Thaniel
Yah I did a bulk translation of the A2L to XDF some time ago. Only had the MS430056 A2L though. And at the time didn't even realize that it was for the MS430056.
I haven't looked at the XDF in awhile. I'm not a tuner pro expert so wouldn't surprise me if there was a mistake in choosing which tuner pro thing to translate too or something. I know a bit more now so could look at it again. But ASAP2demo and the A2L's seem easier to work with at the moment.
I still have the .xls file I used to make the XDF. When I get some time I'll look over the changes Daniel mention. Making a new XDF isn't as easy as making my A2L updates, which once the change is made is simply is copy, paste and save. It's more like Copy, paste, copy, paste, copy, paste then save
Here's a link to where I shared the XDF in April :-)
http://forum.e46fanatics.com/showpos...&postcount=123
Thaniel
Old 08-15-2014, 03:26 PM   #36
new//M3fan
My Ride: 77' 924 87' E30
Yes there is. Don't post if there is nothing you have to contribute, thread gets loaded with worthless posts
LMAO!!!!
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 08-22-2014, 03:58 PM   #37
daniel_f.
My Ride: 330iC
ID:	570342   Click image for larger version
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 09-02-2014, 02:34 PM   #38
sbrach
My Ride: E46 and E53
I would like to be of assistance if possible. I swapped a M54B30 out of an 05 330i ZHP into a 02 325i. I converted the ZHP motor to MS43 and have tried a few factory software versions, currently running the EU2 program 7545671. I am no where near your guys level with deciphering the software but if anything I can do would be helpful then just let me know and I will do whatever I can.
-Steven
sbrach is offline   Reply With Quote
Old 09-02-2014, 02:57 PM   #39
Thaniel
No big updates in the last weeks as i have been on holiday.
I found some more abbreviations and some some maps to begin tuning with and interestingly i found something which i cant tell whats going on, but im curious it may have something to do with dtc switches...
I may be completely wrong here, but if we keep in mind the alpina engine doesnt have a exhaust vanos...
Yah same here. Holidays and other projects been pulling me in other directions.
Interesting. Wonder what the best way to verify this would be? Have you tried Unpluging the exhaust cam sensor (will cause an error code) and then changing that setting and see if the error doesn't show.
Thaniel
Old 09-02-2014, 03:18 PM   #40
daniel_f.
My Ride: 330iC
Siemens MS42 wiki!
Siemens MS43 wiki!
