Go Back   E46Fanatics > Everything Else > The Off-Topic > Home Improvement
Home Improvement
Home Improvement ideas, help, DIYs, and show room. Got a home improvement project you need help with or want to share. Post your project now!
Old 07-13-2014, 03:47 PM   #1
sandman512
My Ride: 2005 325I
Looking for some advice on how to make Volley Ball Poles semi-permanent.
I am looking to install a volleyball net. Ideally, I would like to have it where the I can install the net as needed, so I would like to something where I can install the poles into a permanent hole in the ground. Just not sure how to attack this, any advice? Thanks.
sandman512 is offline   Reply With Quote
Old 07-14-2014, 09:54 AM   #2
SamDoe1
My Ride: 4cyl of fury
Install concrete in ground with short (~6") high post that's a little smaller OD than the ID of the real post. Drill hole through ground post. Take real post, drill matching hole and put over ground post. Bolt in place. Take bolt out and remove real post when not needed.
Make sure you make a cover or something for the ground post so people don't trip over it and sh1t.
Old 08-01-2014, 02:45 PM   #3
WDE46
My Ride: '13 128i, '04 330Ci
Flush hidden solution is to do the opposite of what Sam suggests. Put the larger ID pipe in the ground a couple feet deep, maybe into a concrete footing. Then your volleyball poles simply slide in and out. You can cover the pipe in the ground with a grommet of some kind.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 08-03-2014, 07:18 AM   #4
Vinnie Vega
My Ride: 0032870Vette70Velle
That's what I'd do. I'd use PVC, and also level the volley ball posts with concrete INSIDE the pipe. PVC is incase somehow you manage to knick it with a lawn mower or something it wont get destroyed, and it'll never rot out, and it's cheap as ****.
"I'm like Swayze mixed with Sajack"
Vinnie Vega is offline   Reply With Quote
