Sponsored by BimmerWorld
Old 07-14-2014, 02:23 PM   #1
JustChill
My Ride: 2004 330Ci
New pads not making full contact?
Hey guys, I searched for this topic but didn't find anything, so apologies if it's been covered.
I recently replaced the pads on my 330ci (pagid reds from bavauto) on all four corners. Install went off without a hitch and everything feels fine while braking. However, I have noticed on my driver side rear rotor, a ring of rust from what I assume is the pad not making full contact with the rotor. It's only on the driver's side, which I think is weird
I have bedded the pads once, but was planning on doing it again today. However, if that doesnt work I am out of ideas. Any thoughts? It looks awful and I cant imagine that ring building up is good for anyone
JustChill is offline   Reply With Quote
Old 07-14-2014, 06:47 PM   #2
JustChill
My Ride: 2004 330Ci
Pictures now:
http://imgur.com/ZGSWxmF,Aazb1W3#0
Old 07-14-2014, 07:08 PM   #3
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
You need to disassemble the drivers rear & diagnose the problem. If at that point you can't figure it out, start snapping pics so we have a shot at helping you.
Good luck,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 07-15-2014, 05:28 AM   #4
paraklas
My Ride: ESS TS2 320ci
What if... the previous pad has worn the rotor unevenly and the new pad simply doesn't touch the over-worn part?
Old 07-25-2014, 09:49 PM   #5
Dirtybrd
My Ride: 02 330ci
Did you have the rotors machined or just slap pads on?
Dirtybrd is offline   Reply With Quote
Old 07-29-2014, 06:37 PM   #6
wallofgrath
My Ride: 2001 330Ci
Did you install the factory brake pad retaining / anti-rattle clips? The pads probably just need time to wear down a bit.
wallofgrath is offline   Reply With Quote
