Sponsored by BimmerWorld
Old 07-15-2014, 05:37 PM   #1
jon-k
My Ride: 2002 325i
Koni FSD's still the shocks to get?
Getting ready to overhaul the suspension of my e46. I have stock non sport right now. Looking for something that isnt too harsh for daily driving but delivers much better handling for spirited driving and maybe a little autox/track in the future. Not looking for a dramatic drop either. The subtle drop of the eibach kit sounds right to me. Based on the sticky thread looks like the koni FSD + eibach pro kit is the way to go. All the threads about this setup are 4-8 years old though. Just wondering if something new is out that supersedes the konis (ie better handling and more comfortable at similar price point) or are the koni FSD's still a good option. Thanks!
jon-k is offline   Reply With Quote
Old 07-15-2014, 06:10 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
You really need to pick 1) Comfort or 2) Handling. I say this because the FSD is a good shock geared more towards comfort, with sporty driving mixed in. But it is Not the strut/shock of choice to ever track or autoX with. So if you want a spirited / sporty DD with the ability to autoX or track, you'll want a different shock. If you never wanted to autoX or track, then the FSD would work well, but you want that option so pick either a Bilstein Sport or Koni Sport & you'll be better off.
Good luck,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 07-16-2014, 09:09 AM   #3
jon-k
My Ride: 2002 325i
Good luck,
Rob43
Well I guess comfort because tracking is a far off dream/possibility. Im sure I'd still have a blast if I took it to the track once or twice. Thanks for the advice!
Old 07-17-2014, 04:14 PM   #4
Pole position
My Ride: E46 330ci
I like my koni fsd's. I though the front struts blew prematurely but I can't see any leaking oil so they must be fine. The car handles better and still autox's well. Tire rack recorded a faster time with the fsd over the stiffer koni yellow too.
Shut up and drive
Pole position is offline   Reply With Quote
Old 07-18-2014, 12:29 AM   #5
SoCaLe39
My Ride: 06 M5 & 03 325i
Just installed my FSD kit over the weekend and I'm extremely happy with the handling.
SoCaLe39 is offline   Reply With Quote
