Old 07-16-2014, 12:36 PM   #1
rifraf
My Ride: 05 325ci
Cog of Death,, Tranny fail-safe mode - Recommendations?
Hi guys,, On Monday I got the love cog of death while driving home. Had to limp it back and then limped it to the local BMW dealer to find out whats wrong.
Here's my car info
2005 325ci
143k miles
Auto Trans
The tech did a diagnostic and didnt find any errors, but recommended I replace my transmission at $5400. Uhh,, what????? He reset the fail safe and I drove it home with no issues.
So what do you guys reccommed? I know when you get the cog of death it could be a millions things that could have gone wrong. Bad tranny, Bad battery, Bad sensor, the list goes on.. What do you guys think I should do?
I love my car, and other than a fuel pump replacement and regular maintenance, the car has been rock solid.
rifraf is offline   Reply With Quote
Old 07-18-2014, 11:32 AM   #2
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: used to be an auto
Uh what the hell. 'I dont know what it is, so let me quote you the most expensive thing i can think of'. Burn in hell mechanic. Check your MAF first. Caused the gear light on mine.
Modification Thread
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 08-13-2014, 02:10 PM   #3
Das_e30
My Ride: 2000 328ci
Had the same thing on mine, turned out camshaft sensors were/were going bad. Changed the MAF sensor, it went away, for a little, then it happened one more time and I changed the fuel filter and it all went away...
Das_e30 is offline   Reply With Quote
Old 09-23-2014, 01:46 AM   #4
E40SICK
My Ride: 2001 330ci
did this get fixed? my car kept going into fail
safe because of a bad battery that didnt hold a full charge.
E40SICK is offline   Reply With Quote
Old 09-26-2014, 01:27 AM   #5
HakenTT
My Ride: 323i with S54
mechanic checked via generic OBD2 scanner, showed nothing. That is because he needs to scan BMW factory, codes, it will say why the transmission is in safe mode.
Siemens MS43 tuning master
HakenTT is offline   Reply With Quote
