Really harsh ride with 18" bridgestone runflat tyres - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by The Tire Rack
Old 07-18-2014, 06:27 AM   #1
Antti
My Ride: German car
Hi, i recently bought e46 325i facelift which has following setup:
Standard shocks
Eibach sportline lowering springs
18" oem wheels 215/40/18 + 245/35/18 Bridgestone potenza runflat wheels
Ride is so harsh that i think my tooth will fell off.. Is that because of lowering or is those runflat tyres causing it?
Antti is offline   Reply With Quote
Old 07-18-2014, 06:40 AM   #2
Dirtybrd
My Ride: 02 330ci
Run flats are known to have a horrible ride
Dirtybrd is offline   Reply With Quote
Old 07-18-2014, 06:43 AM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Most runflats do give a rather harsh ride, but this coupled with lowering springs probably makes the ride far worse.
Old 07-18-2014, 07:01 AM   #4
Antti
My Ride: German car
Okay, so i will throw those to thras can.
I just bought set of original style 68. 17".. next is to order set of tyres. NOT runflat
Old 07-18-2014, 10:27 AM   #5
Dirtybrd
My Ride: 02 330ci
Sell them. Run flats have extremely thick and stuff sidewalls, hence to harsh ride. Being a low profile tire just makes it worse.
Old 07-18-2014, 05:43 PM   #6
isellbrakepads
Account Under Review
My Ride: 2000 BMW 328i
The only runflat you can get right now that doesn't ride like that is the Driveguard from Bridgestone. The actual Potenza line of runflats from Bridgestone will definitely have a harsh ride.
isellbrakepads is offline   Reply With Quote
Old 07-21-2014, 02:18 PM   #7
generalvp
My Ride: 05 330ci
I currently have Bridgestone Potenza RE050A run-flats and they are stiff as heck. With the added stiffness of the sports suspension, it gets real bumpy most of the times. I'm waiting for them to wear a little bit more before I change them to non-RFs.
generalvp is offline   Reply With Quote
Old 07-21-2014, 02:30 PM   #8
Rudy@Tirerack
Moderator
Rudy@Tirerack's Avatar
My Ride: 1-800-428-8355 X4664
The Bridgestone Driveguard is indeed the softest riding run flat tire if you decide that you'd like to stick with a run flat.
Tires http://www.tirerack.com/a.jsp?a=BN4&...ires/index.jsp
Refer to 'Rudy/E46Fanatics' as your previous contact when you order online. Credit E46Fanatics.com by clicking here.
Rudy@Tirerack is offline   Reply With Quote
