valve in exhaust tip - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Convertible
Old 07-19-2014, 01:12 AM   #1
rcflyer2
My Ride: 330xu
I'm fairly new with my 330Ci convertible and was kinda disappointed on how extremely quiet it is. After reading a few posts about exhaust sound I inspected my exhaust valve or flap or whatever its called inside the right muffler tip and found it to be tottaly stuck closed So I took a metal rod I had laying around and poked it a few times and was able to pry it open its fairly stiff so I decided to leave it in the stuck open position to see if there was a difference, figuring if I didn't like it like that I could spray pee oil on it and free it up to at least to make it work right. It is noticeably louder but not by any means loud. I think I'm just gonna leave it in the stuck open position. throttle response seems to have improved a bit also. Will it harm anything to leave it like that?? thanks Lou II from Niagara Falls
rcflyer2 is offline   Reply With Quote
Old 07-19-2014, 04:22 AM   #2
bigguy
My Ride: 2001 330ci vert
won't hurt a thing, everyone is doing it.
bigguy is offline   Reply With Quote
Old 07-19-2014, 09:00 AM   #3
rcflyer2
My Ride: 330xu
thanks Bigguy
Old 07-20-2014, 08:49 PM   #4
rcflyer2
My Ride: 330xu
well so far my car is sounding better and after filling up I find I am getting at least 3 mpg better fuel economy !!!! sweet finally getting over 22mpg up over 25mpg now.
Old 07-22-2014, 02:26 PM   #5
The Snake
My Ride: 330Ci
If you want it louder on a budget, a simple muffler delete will do the trick. It cost me $100, and it sounds great, although it does drone once in a while
"If you aren't driving a stick shift BMW, you're just steering"
Suspension: Koni Yellow Struts, Rob43 Shocks, H&R Race Springs, ZHP Control Arms, Meyle HD bushings
Drivetrain: ECStuning Lightweight Flywheel + E34 M5 Clutch kit, 545i shifter
Interior: GSP Mason Clutch Pedal, M3 Seats, M3 Steering Wheel (Coby), ZHP Knob
Misc: E90 Chime Retrofit, CF Strut Bar, VMR V703 CSL Rep. Wheels
The Snake is offline   Reply With Quote
Old 07-22-2014, 05:07 PM   #6
rcflyer2
My Ride: 330xu
how do you do a muffler delete???
Old 07-27-2014, 07:31 AM   #7
djsilver
My Ride: '01 330Ci Vert
The valve you speak of has a vacuum hose run to it and is supposed to open when you stomp the go pedal and intake vacuum drops. Being in the exhaust system, they tend to get stuck. Ours has been stuck open since we bought it and just leave it there. If the vacuum hose is cracked or broken it causes a vacuum leak and can affect idle. It can be corrected by plugging the hose.
djsilver is offline   Reply With Quote
Old 07-27-2014, 07:49 AM   #8
E46DrEaMeR
My Ride: 2004 330ci
sorry don't mean to hijack the tread but can anyone tell me where the other end of the vacuum pipe connects to ?
Its a ragtop thing! you wouldn't understand
E46DrEaMeR is offline   Reply With Quote
Old 07-27-2014, 07:23 PM   #9
rcflyer2
My Ride: 330xu
Yeah DJ mine was stuck I had to hit it and pry it open so I will just leave it stuck open for now. It has improved my milage and sounds a bit better toooo. I'm happy with it for now and it was a zero cost improvement. Lou
