E46 Convertible
Old 07-20-2014, 08:35 PM   #1
bmw330cice46
Key won't work, car thinks tops open
So... My top stopped working a while back and well I've been opening and closing it manually. But since then I haven't been able to use the remote (slightly annoying if you're still the type to open doors for the ladies) Is there any way of tricking the computer into thinking the top is closed and deactivating the fob? I might add the keys I have are newClick image for larger version
ID:	566098Click image for larger version
bmw330cice46 is offline   Reply With Quote
Old 07-21-2014, 11:39 AM   #2
dknightd
My Ride: 2002 330 cic
I don't think the top position effects key fob function (at least mine work with top up, or top down.)
When you got the new key, did you program it for the car? If not, google e46 program key - and follow the steps.
If you did, you might try doing it again (but this should not be necesary).
dknightd is offline   Reply With Quote
Old 07-21-2014, 03:41 PM   #3
jfoj
My Ride: 330CiC, M5, X5
http://www.bmwgm5.com/key_recode.htm
Old 07-21-2014, 06:31 PM   #4
bmw330cice46
I think it has to be programmed when the top is closed though
Old 07-21-2014, 06:31 PM   #5
bmw330cice46
I'll try it though
Old 07-21-2014, 07:18 PM   #6
dknightd
I programmed my spare key with the top down. Just for fun today I tried the buttons when the roof was half open - they unlocked and locked doors just fine. It did confuse my top, being stopped part way open, but with a little help it remembered what to do. I don't think the lock and unlock function care about the top. They do care if the door is open or closed.
I did not try to reprogram my key with the top stuck part way open. I'll bet it would work fine.
Let us know what you find so the next person who comes along can gain from your experience.
Old 07-22-2014, 03:32 AM   #7
bmw330cice46
Yeah I'm going to do a bit of research and see what I can do I feel like it can't be programmed until it's completely locked :/
