Sponsored by BimmerWorld
Old 07-21-2014, 09:27 AM   #1
riverwolf
My Ride: 2005 330Cic ZHP
Question Per Bentley/TIS: ride height same for all body styles?
Subject is a 2005 330Cic Vert with sport suspension (ZHP package) with 83K miles. I'm the 4th owner (purchased in April) and in the process of trying to refresh her a bit. Koni Sports sitting in the garage, but I'm trying to decide if I need new springs as well.
Per Bentley/TIS, the only variables in ride height regardless of body (coupe/vert/sedan/wagon) are suspension type and wheel size. Has this been confirmed accurate or has incomplete information been published?
Per the numbers, I appear to need new front springs at only 83K. My front is even left/right, but I'm ~.25" below minimum spec (mean - tolerance) for the Sport suspension even without the 500# of ballast and only half-tank of gas...so really about 550# light per the measurement procedure and I'm still low.
For completeness, rear is also level left/right and measures on the high side of mean spec (within tolerance), again with measurements made missing about 550# of ballast. This would suggest Bentley/TIS is accurate.
Thoughts/feedback?
Thanks!
riverwolf is offline   Reply With Quote
Old 07-22-2014, 11:27 AM   #2
bimmernate
My Ride: 2003 330i ZHP
you don't need to swap out the springs unless they are rusted or broken.
2003 330i ZHP 6MT
Performance: Koni Sport Struts/Shocks, Eibach Pro-Kit, 17x9 Apex ARC-8, TMS F&R Sway bars, M3 RTABs w/ Vorshlag Limiters, M3 Strut Brace
Aesthetics/Functionality: TFX Projector retrofit by lightwerkz, 20% Tint, OEM Aux Input, Clear corners, LED taillights, M3 Steering wheel, Black kidney grills, mobius dash cam
bimmernate is offline   Reply With Quote
