Sponsored by BimmerWorld
Old 07-21-2014, 03:12 PM   #1
stephenn
My Ride: '03 325 Ci
Rear Shock detached
Anyone else ever had this happen shown in photo?
From my very limited knowledge, it looks like the bolt is still in but maybe the washer failed. Thoughts?
If that's the case, it's as easy as removing the bolt, reinstalling the shock, and then reattaching with a new washer and existing bolt correct?
Am I missing anything?
stephenn is offline   Reply With Quote
Old 07-21-2014, 03:27 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
It looks like the washer was Not installed. Pull the bolt off & get yourself a washer that fits, make sure the washer has a big enough diameter to cover the entire rubber bushing. Then re-install.
Good luck,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 07-23-2014, 05:08 PM   #3
JB707
My Ride: 2001 DINAN 330 CI
what he said ^^, same thing happened to me and of course make sure to do the same to the other side as well! GL
DINAN:COLD AIR INTAKE, THROTTLE BODY, STAGE 3 CHIP, FREE FLOW EXHAUST
BB PERF HEADERS // RESONATOR DELETE // EE LED TAILS // M3 LIP SPOILER // DICE IPOD INTEGRATION // DIY FRONT REFLECTORS // UMNITZA ORION V2 ANGEL EYES // KONI YELLOW SPORT // H&R RACE SPRINGS // ROGUE RSM's // POWERFLEX FCAB // CLEAR FRONT SIGNALS // CLEAR SIDEMARKERS // LED FRONT SIGNAL BULBS // LED SIDEMARKERS
JB707 is offline   Reply With Quote
Old 07-23-2014, 05:20 PM   #4
stephenn
My Ride: '03 325 Ci
Yeah, I looked at the other side and the washer is missing there also. I am having a hell of a time finding a 19mm washer. I have tried the big box hardware stores, 2 different automotive chains, and a couple of local automotive machine shops with no luck. I am about just use a small piece of this sheet metal and drill a 19mm hole in it. UGH!!!!
These shocks were installed 18 months ago so I can't believe that they are stayed on this long.
Old 07-23-2014, 05:26 PM   #5
Rob43
Rob43's Avatar
If you can't find what you need in a washer, you could Fab something like a 1"X 2" by 1/8" thick & drill your hole. It doesn't necessarily need to be round.
Good luck,
Rob43
