Windscreen wash reservoir empties overnight... - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-21-2014, 05:00 PM   #1
fuffa123
Hi,
Windscreen wash reservoir won't hold screen wash. Have removed, nothing obviously wrong. Empties from full overnight.
Leak is under reservoir (drivers side).
Any suggestions, washers seem ok?
Cheers.
fuffa123 is offline   Reply With Quote
Old 07-21-2014, 05:42 PM   #2
330cic2002
My Ride: 330cic2002
Originally Posted by fuffa123 View Post
Hi,
Cheers.
I'm battling the same problem currently and bought a box of mixed sized vacuum hose plugs and have plugged various parts of the system, filled it back up with water and waited for the leak.
In my case it was the washer motor itself (not the one for the headlights).
Additionally, there are several threads about this topic - try doing a search.
330cic2002 is offline   Reply With Quote
Old 07-22-2014, 06:39 PM   #3
fuffa123
Cheers mate. It's a bloody annoying problem.
Old 07-24-2014, 07:28 PM   #4
Nickvjr
My Ride: 2004 330Ci Conv.
Send a message via AIM to Nickvjr Send a message via Yahoo to Nickvjr
If you don't have a headlight washer system, then I would suspect the washer jet motor or rubber plug maybe the cause of your leak. The rubber plugs are a cheap fix and motors can be found online for $10-20. If the reservoir is cracked, a used one should be readily available. I see them on eBay all the time from people parting out their E46s. Good luck!
-Nickvjr
2004 BMW 330Ci Convertible
Nickvjr is offline   Reply With Quote
Old 07-25-2014, 04:42 PM   #5
bimmernut3
My Ride: '05 330cic, '01 540i
Hi,
Cheers.
Fuffa123...I had the same issue last month in my '05 330Cic. I pulled the reservoir out & checked for leaks around the pump but all looked ok. I eventually found that it was leaking from the barbed connector at the small outlet tube. Cut a small amount of the end of the black tube off & reconnect. I believe the tube takes a set after time & allows the fluid to leak past.
'05 330ci
[IMG][/IMG]
bimmernut3 is offline   Reply With Quote
Old 07-12-2015, 07:33 AM   #6
CabrioPassion
My Ride: 330Ci Cabrio M.T. II
Hi to all. My car's washer jets "loose" liquid by itself, I don't know why, but I found blot strips from they on hood. They work good when activate, no low pressure too, so I don't know what's happened.
Any ideas?
Thank's to all.
CabrioPassion is offline   Reply With Quote
