Sponsored by BimmerWorld
Old 07-22-2014, 11:57 AM   #1
hoppa79
My Ride: needs more cowbell
Alignment Review
Can I ask for some input regarding my recent alignment?
The numbers, especially for the rear camber are scaring me.
I'm wondering if I should get it redone?
hoppa79 is offline   Reply With Quote
Old 07-22-2014, 12:38 PM   #2
Tangent_
My Ride: '01 330i, '11 Z435i
Rear camber isn't adjustable on our cars without installing an adjustable lower control arm. While it's more camber than specified, it's at least pretty even. Is your car lowered? That would account for the extra camber... That or worn out bushings.
http://forum.e46fanatics.com/signaturepics/sigpic70081_4.gif
Tangent_ is offline   Reply With Quote
Old 07-22-2014, 03:54 PM   #3
generalvp
My Ride: 05 330ci
Unless you purposely want more negative camber, you should get it re-alignment. I had mine done a week ago and the rears were also out of spec and the tech. I asked the tech if it was possible to correct the rear camber and he said "yeah" and I watched him do it. and my suspension is all stock.
generalvp is online now   Reply With Quote
Old 07-22-2014, 05:53 PM   #4
Dave1027
My Ride: '06 IR zhp coupe
The major problem with this alignment is the cross camber up front. Was this car ever in an accident? Might have a bent front subframe.
The shop did a terrible job. Why did they increase the rear left camber? That was the good side! Are they color blind? OP, did you specifically ask for all that rear camber?
Dave1027 is online now   Reply With Quote
Old 07-22-2014, 08:24 PM   #5
Minnoe07
My Ride: 2004 BMW 330Ci
Rear camber is adjustable and should be put within spec.
Front camber is also adjustable but requires a little work that most shops won't do.
I don't accept alignments where camber and toe left to right are off by that much.
2004 330Ci 6 Speed; UUC Sway Bars; Powerflex RTAB's and FCAB's; KW V2 Coilovers; 3.38 OS Giken LSD
Z4 Finned Diff Cover; Headers; M-Tech II Rear Bumper and CF Diffusor; CF Trunk; CSL Front Bumper
M3 CF Hood; DICE I-Pod Kit; JTD Rear Shock Mounts; UUC Front Strut Bar; O2 Simulators
ESS TS2 Twin Screw Supercharger
Minnoe07 is offline   Reply With Quote
Old 07-23-2014, 02:29 PM   #6
hoppa79
Thanks for all of the input everyone, I appreciate it.
No history of accidents.
The car had new fcab and rtab bushings installed along with new tires prior to alignment.
You helped confirm my suspicions that the shop did a shoddy job.
I made a really poor decision in getting the alignment done there and will be taking it to another shop for re-alignment.
