Sponsored by BimmerWorld
Old 07-25-2014, 09:18 AM   #1
Weste46
My Ride: 2001 330ci
Coupe rear end links
I tried searching for a quick DIY but didn't find one for a non m coupe.
I got under the car and looked at them real quick, and it looks like I could do it with the car on the ground pretty easily. Is there something to this that I'm not getting or is it just that easy?
Corbeau FX1 Pro & CR1, Ultimo front coils, Rob43 9-click rear shocks, Swift 10k rear springs, Meyle FCA's, AKG 95a FCA, 75d rear subframe, Powerflex 95a RTA, 95a RCA, ECS 88a diff., ECS SS brake lines, LTW FW, M3 engine mounts, UUC 5sp black mounts, BMW Performance SSK, open-loop EU2 tune, CAI, headers, x-pipe, minus ~180lbs.
Weste46 is offline   Reply With Quote
Old 07-25-2014, 09:58 AM   #2
markusmarkus
My Ride: 2001 330Ci
They can be removed with the car on the ground, if you Hercules. Why? The roll bar is tensioned. Put the rear end on jack stands, remove the wheels.
Old 07-25-2014, 10:20 AM   #3
My Ride: Lexus
how will you fit under the car without lifting it up? just lift the rear.
also why are you replacing them? rear links really do not wear. i've seen them on 300,000 mile 15+ year old e36s and they are as solid as brand new pieces.
Old 07-25-2014, 11:21 AM   #4
WDE46
My Ride: '13 128i, '04 330Ci
They're the same as Sedan links man. Even if they're not, it couldn't be much simpler. It's two bolts and two nuts per arm left and right and then two nuts and bolts holding the bushing brackets to the middle of the chassis. You need a two 13mm wrenches and a 17mm.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 07-25-2014, 11:24 AM   #5
My Ride: Lexus
coupe links are better handling bro. c'mon
Old 07-27-2014, 12:35 AM   #6
Weste46
My Ride: 2001 330ci
my sway bar bends easily, so I was replacing the bushings and end links. I guess the 19mm bar could just be too small, but I can move my bar with my thumb on the end.
