Sponsored by BimmerWorld
Old 07-25-2014, 12:38 PM   #1
mjose
My Ride: 2000 328Ci
Driver side front wheel rubs on swaybar
While making a sweeping right turn on a exit ramp I felt the driver side wheel rub on something. When I parked the car and did a visual inspection, I noticed the driver side sway bar had some rub marks..any idea what would cause this? First time this has happened to the car. suspension setup is H&R sport cup kit, Kosei K1's w/ 235/40/17 and H&R swaybars and TMS adjustable links.
mjose is offline   Reply With Quote
Old 07-25-2014, 12:47 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
I have a thought on this, but first tell me how much clearance there is when it is just sitting on a flat surface.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 07-25-2014, 02:21 PM   #3
mjose
My Ride: 2000 328Ci
fender clearance?
Old 07-25-2014, 02:35 PM   #4
Rob43
Rob43's Avatar
No, I'm asking about your rubbing problem. So between the wheel and the sway bar. How much clearance as it sits on a flat surface ?
Rob43
Old 07-25-2014, 02:42 PM   #5
mjose
My Ride: 2000 328Ci
oh ok, i'll measure when i get home and on ramps.
Old 07-25-2014, 02:54 PM   #6
Rob43
Rob43's Avatar
If you can see it without the ramps or just stick your finger up there, that would be best. I fear that ramps or jacking might change things, that's why I suggested a flat surface. But do what's best/safest for you.
Rob43
