Garage door opener problem. - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-11-2003, 10:42 PM   #1
2002330i
My Ride: 2002 330i
Send a message via AIM to 2002330i
I recently bought and installed the garage door opener module for my 2002 330i. I pluged it in a nd it didnt work. I ws wondering if it nee to be acivated by the dealer. Has anyone ever had this problem. Please write back.
2002330i is offline   Reply With Quote
Old 08-11-2003, 11:04 PM   #2
ecng
No more mods
My Ride: 325I
I have no problem and you don't need to activate
ecng is offline   Reply With Quote
Old 08-11-2003, 11:14 PM   #3
WarSong
Obey my dog
WarSong's Avatar
My Ride: 2007 Audi A4 3.2Q
Send a message via ICQ to WarSong Send a message via AIM to WarSong Send a message via MSN to WarSong
do the lights on it turn on at all?
WarSong is offline   Reply With Quote
Old 08-11-2003, 11:22 PM   #4
sycE46
My Ride: 323ci
Does your garage door opener have rolling codes? you might need to program your opener.
sycE46 is offline   Reply With Quote
Old 08-11-2003, 11:27 PM   #5
fasteddie
INDEED
My Ride: 2OO2 OrientBlue 325i
no, but you hafta program it
2002 325i alarm.clears.ddeLightningEnhanced.fstb.gaugerings.gruppeM.kw V2coilovers.M3lipspoiler.M3sidemirrors.M3pedals.M3wheel.
modaR1-17s.paddles.paintedmoldings.titaniumEbrake.UUCsways.UUCubbk - cornerbalanced!
fasteddie is offline   Reply With Quote
Old 08-12-2003, 12:16 AM   #6
hamann99
X-Hamann99
My Ride: 323i->350Z->87 325is
Send a message via AIM to hamann99
read the instructions, you'll have to prgm it like fast eddie mentioned which is like a 2 min job.
Any fool can drive in a straight line
hamann99 is offline   Reply With Quote
Old 08-12-2003, 03:04 AM   #7
TeKNiC330
Banned
My Ride: IS ON STOCK 17'S
i think you have to program it
TeKNiC330 is offline   Reply With Quote
Old 08-12-2003, 04:26 AM   #8
egyptnads
Banned
My Ride: 2000 silver 323i
Send a message via AIM to egyptnads
i think its broken
egyptnads is offline   Reply With Quote
Old 08-12-2003, 07:36 AM   #9
2002330i
My Ride: 2002 330i
Well its a new part right out of the box from the dealer. I tried programing it. the little yellow light should light up when you press a button. This is really wierd.
Another thing, the wiring plug that plugs into the module. I had to brake of a little tab for ir to fit. Did you guys have to do that also?
Old 08-12-2003, 11:52 AM   #10
peterpan223
My Ride: 330Ci
No, it should fit right in
peterpan223 is offline   Reply With Quote
Old 08-12-2003, 02:00 PM   #11
Conrad
Modelrater
My Ride: 2000 323ci
Send a message via AIM to Conrad
You shouldn't have to break any tabs off. It's a perfect fit. Make sure you also have the car on. Otherwise there is no power to the opener.
Conrad is offline   Reply With Quote
Old 08-12-2003, 02:22 PM   #12
Jano
My Ride: 2001 330i
It's been a while but I think there is more than one wiring harness is that general area. In fact, if I remember correctly, I really had to dig around to find it. It should fit perfectly. BTW - they don't work all that well anyway, especially if you have a newer garage door or gate that uses rolling codes. I have to practically be close enough to ram my garage door before it opens.....the cheap-ass remote that came with it opens it from half way down the block.
Jano is offline   Reply With Quote
Old 08-12-2003, 02:54 PM   #13
notE46
Where am I?
My Ride: M Coupe
okay i went through the same thing.
you found the black connector 3wire plug right. that is not the right one. I assume that was the right one as well. The correct connector is colored white and should be tucked on the passenger side. It's hard to see and I had to use a screw driver to get the connector out.
go drop the panel then then light cluster and look for another bundle of wire on the passenger side. You'll find it there. Also it was hard to plug the black connector reach the homelink right it's because it was meant to be plugged into a mic for the cellphone.
'87 325iS Sold but not forgotten.
'08 MINI Cooper S Mellow Yellow
'00 M Coupe Dakar Duck
'02 330ia
notE46 is offline   Reply With Quote
Old 08-12-2003, 02:56 PM   #14
notE46
Where am I?
My Ride: M Coupe
my friend cautioned me of the poor range as well. but I can open the garage door 1/2a block down. by the time i reach the driveway the garage door is fully open.
the remotes that came with the opener only work if I'm in the driveway and I also have a rolling code garagedoor opener.
'02 330ia
Old 08-12-2003, 04:45 PM   #15
vernong
My Ride: Steel Gray 01 330ci
Send a message via AIM to vernong
problems
Some people have had problems with there garage door transciever from HomeLink either in the way you program it do to the new rolling code,in the newer garage door openers or the distance the door opens.I myself had both problems.Just get in touch with HomeLink at www.homelink.com or 1-800-822-2399 between the hours of 7:30am to 5pm,EST. They sent me a up graded tranciever which JMK BMW installed free of charge and told me how to program it to the rolling code.Now everything works fine and the door opens up at 300 -400 feet.
Good luck
vern
vernong is offline   Reply With Quote
Old 08-12-2003, 05:15 PM   #16
2002330i
My Ride: 2002 330i
Thank you so much guys for the info. It was a great help. You just saved me a SH*T load of money.
Thanks again
Old 08-12-2003, 06:23 PM   #17
notE46
Where am I?
My Ride: M Coupe
Thanks again
no problem I went through the same thing and someone on the one of the other board helped me out
'02 330ia
